Discussing changing my power steering pressure line in the 5.0 Mustangs Forum. ok im replacing the pressure line for my power steering.....it goes from the side ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1990 Mustang GT
9.39@76.09----1/8th mile
ok im replacing the pressure line for my power steering.....it goes from the side of the power steering pump down to right behind the the rack and pinion.....is there some special way to get this thing off because everything is so tight in there.....i got it most the way off and now the part you put the wrench on has raised in line with another line and i cant get a wrench on it.....if anyone has any advice or experience it would be appreciated....if not im just gona pull of the rack and pinion just to get to it
1990 Mustang GT
bumb
1988 Mustang GT Hatch
I changed my line over the summer and ran into the same problem as you. Only way to do it is take the rack off. While your at it you can change the rack bushings to polyurathane ones. They give you a better steering feel
1990 Mustang GT
where are the bushings at on the rack
Threads Similar to: changing my power steering pressure line
| changing power steering pressure line | Iwannagofast | 94-95 | 1 | January 21st, 2008 11:51 PM |
| Fuel Pressure Regulator Vacuum Line | mscribellito | V6 Mustangs | 7 | December 20th, 2007 03:18 AM |
| power steering pressure line | Stang6899 | Suspension | 1 | October 9th, 2007 07:45 PM |
| Decreasing power steering pump pressure for tighter steering | 83 5.0 | 5.0 Mustangs | 6 | January 7th, 2007 09:24 PM |
| OMG Please Help (Power Steering Line) | 305STANG | 99-04 | 7 | September 6th, 2006 11:41 PM |
