Foglights + Parking lights
Hey guys found something useful. been looking to do this forever, might even solve some of your headlight problems if you have any.
Mustang GT Fog Light Fix great article
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
started doing this when i posted...
now i am done. its amazing.!
13.64@101mph
dont own a gt and not gunna read it...but teh what does it do?
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come |
1987 ford mustang gt
well see when shes done
Well i bet your damn vin says your car is a gt!!!
if you read it you would know
when you turn on the parking lights and foglights, they both come on, instead of them only being on while headlights are on. plus they dont turn off when you put on high beams xD
88 mustang GT
oh i like...
how much did it end up costing you and how long did it take? |
i was just about to ask that
13.64@101mph
shut up...no 1 knows...
13.64@101mph
gotcha...thats pretty cool
#11 | |
That article is cool, but they way over complicate the wiring. All you need to do is run a switched 12V source (through whatever switch you want to use, stock, or other) to a relay and a fused constant 12V source to the power side of the relay. You don't need to tear apart the dash or touch any of the dash wiring. If you want to still use the factory switch, you just pull the switched wire from where it goes into the fog lights (the white wire). Way easier to get to than pulling the dash apart.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
then why dont you just come on over and do it for me
Bring your car, a 30 Amp relay from autozone, and 10 feet of 10 guage wire and I'll do it for you...it'll take about 15-30 minutes depending on if you want the terminals soldered or not....
That's what I did, cut one wire (the +12v that runs to the fog lights just before the drivers side light plug), added that, a wire and a fuse to the battery all to a relay. It all fits easily behind the headlight with the relay mounted to some existing sheet metal screw. Now my fog lights work exactly like before but get power through a fuse directly from the battery. No more headlight flickering and all work was done in the engine compartment near the battery. I used heat shrink and solder for the connections and a socket for the Bosch type relay but that is not required. Like you said, about 15 minutes.
This may not be of interest to some but if you do any electronic stuff or car accessories wiring, All Electronics Corp - Parts, Supplies and Components is a decent source for stuff.
#16 | |
This is exactly what I've been trying to do without tearing up dash. Could you diagram your process or show pixs using stock switch? I would GREATLY appreciate and am sure others would use as well. Thanks a lot!! |
Ryans88gt description is dead on. Thanks to his help, I now have my fogs running whenever I want, and using the stock fog switch. Great tip!!
Converted to 5 Speed, Cervini functional Ram Air Hood, BBk Headers & Flowmasters, 3:27s |
Threads Similar to: Foglights + Parking lights
| removing foglights | JaxnsGT | 99-04 | 9 | October 26th, 2007 05:38 PM |
| Switching to GT foglights | trueballerisme | Audio/Video | 7 | October 2nd, 2007 12:58 PM |
| foglights | Nick_Rapitis | V6 Mustangs | 7 | August 15th, 2007 01:28 AM |
| blue foglights??? | tsp_2177 | Visual | 14 | April 20th, 2007 02:10 PM |
| foxbody gt foglights | 1990CA50 | 5.0 Mustangs | 2 | December 12th, 2006 07:58 PM |
