Anybody Ever Heard Of A Cam Thrust Plate Failing?
Old September 16th, 2006, 06:48 PM   #1
JamesR1 is on a distinguished road
Please refer to "I think it might be hurt." I think my cam might have walked out of the block enough to have the cam lobes contact the other lifters causing a horrible noise, loss of power, and a different idle. Is this possible?
Old September 16th, 2006, 06:52 PM   #2
mdvaldosta's Avatar
11.47@120.58
I think your more likely to have broken a rocker arm or bent a pushrod than that happening. Have you taken the valve covers off and checked those yet?
Old September 16th, 2006, 07:02 PM   #3
Sure did. I performed a compression check as well. The engine cranks over smoothly, but when it fires up it sounds horrible, like a 1000 marbles dancing under the intake. With the X cam, it used to have a lumpy idle. Now it is as smooth as a tired 302 out of a pick up. I am baffled.
Old September 16th, 2006, 07:17 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I have seen thrust plates wear from improper timing gear installation - cam bolt backing out which causes the cam to walk.
Old September 16th, 2006, 11:19 PM   #5
I think it could be low oil pressure not allowing the lifters to pump up, causing the noise and the mellow idle.
Old September 16th, 2006, 11:24 PM   #6
I need to manually check the oil pressure and determine if the original noise that I heard was a valve sticking due to no oil. I am more than angry at myself dor not having a working oil pressure gauge....
Threads Similar to: Anybody Ever Heard Of A Cam Thrust Plate Failing?
anyone ever heard of these?? droppedbass87 96-98 1 September 6th, 2007 10:19 AM
Has anyone heard this? rugbyman00 2005 - 2010 5 August 20th, 2007 09:38 PM
anybody heard of BrightWhite98GT 96-98 7 August 3rd, 2007 08:12 PM
Breaks failing? MSTGGT00 99-04 11 July 21st, 2007 03:44 PM
New Here, And More [Car Failing To Idle or Rev Properly Now] daR4V3N 5.0 Mustangs 64 October 4th, 2006 11:48 PM
