Twin Turbo or s-trim sc
Old January 23rd, 2008, 02:31 PM   #1
imported_Gt_Jay's Avatar
1993 Mustang LX
N/A
imported_Gt_Jay is on a distinguished road
Send a message via Yahoo to imported_Gt_Jay
Unhappy
hey guys i found a jdm twin turbo system, or should i just find a sc.
Fastfordsoftexascc.com
Old January 23rd, 2008, 02:40 PM   #2
13.64@101mph
im more into s/c but a twin turbo with obviously make more power
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come
Old January 23rd, 2008, 02:52 PM   #3
ryans88gt's Avatar
You can produce a very streetable T3 twin turbo kit from grand national turbos or 2.3L ford turbos (both are Garrett).
A lot of people have done this for around $2,000.
Old January 23rd, 2008, 02:53 PM   #4
13.64@101mph
you think one outta a junkyard would work?
Old January 23rd, 2008, 03:52 PM   #5
ryans88gt's Avatar
garrett (airesearch) turbos are pretty damn tough and rebuild kits a fairly cheap. As long as they don't have any shaft play or impeller damage, they are usually good to go.
I know at least one guy in town that has 2 grand national turbos mounted a set of lincoln headers swapped upside down. He has a draw through MAF setup with a 2-into one intercooler and some kustom down pipes he welded up himself. He told me it cost him just over $1500 for the whole set up. It's in a totally sleeper looking faded red convertible mustang. Kinda funny.
Old January 23rd, 2008, 04:38 PM   #6
The Razor's Edge
White Thunder's Avatar
jdm = japanese domestic motors
if you want power like this.....
1 aftermarket block
2 aftermarket transmission
3 suspension
4 single turbo kit should be fine
founder of the FTN Club
Old January 23rd, 2008, 05:11 PM   #7
TurboLX's Avatar
1988 Mustang LX Turbo
well JDM does make stuff for mustangs
but first off you gotta know wha you want
like do want a streetable 400hp mustang
or a 500+ strip car?
what kinda money you looking to spend?
how much reliability your willing to sacrifice?
etc etc.....
Old January 23rd, 2008, 09:26 PM   #8
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
I would go turbo thats what my next stang is going to be
Old January 24th, 2008, 12:15 AM   #9
1993 Mustang LX
N/A
I kow that s/c or turbos are high but i willing to spend that for them all in all i like to a have a very streetable 500 hp stang. I have about 4k save for this conversion from 4 to 8 so far.
Old January 24th, 2008, 12:39 AM   #10
notchabovechevy is on a distinguished road
Why not get a cast steel crank good I beams and a set of forged flat tops have a real sleeper with a 200 shot? cheaper and you aren't running the nitrous all the time so it remains streetable? Just my 2cents
Old January 24th, 2008, 06:14 AM   #11
The Razor's Edge
if you have that much money get an aftermarket block.....people say that 5.0's hold 500 but if you abuse it enough it will break too.....some people might say if you have it built right you wont have this problem but oh well
i say forged interinals.....if you do that you might as well stroke it
aftermarktet block
single turbo kit
decent H/I/C
and you could have 500 horsepower all the time with more than 600 on tap if you want it
Old January 24th, 2008, 10:24 AM   #12
TurboLX's Avatar
i seen alot of guys run 9's on a stock block with the beat out of them, as long as you keep it maintained it should last....
for awhile anyway
Old January 24th, 2008, 10:39 AM   #13
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
instead of buying an aftermarket block and stroking it , i would make the move to a 351 windsor , you get more cubic inches stock or you could stroke it to over 400 reliably , you get a better block and bigger head bolts which will help prevent blown head gaskets and it would probably not cost any more then going to an aftermarket 302 block and stroking it
Old January 24th, 2008, 10:55 AM   #14
TurboLX's Avatar
Old January 24th, 2008, 11:40 AM   #15
86_Notch's Avatar
1986 lx notch
9.98 @ 135
Old January 24th, 2008, 12:40 PM   #16
Goblin's Avatar
88mm
Goblin will become famous soon enough
Send a message via AIM to Goblin Send a message via Yahoo to Goblin
He could leave the combo at 351, and just have the better block.. and make 500hp with a single 60mm all day long, with little effort. It would cost less than building a 5.0 with an aftermarket block and rotating assembly. Plus, with a 60mm turbo.. the boost response would be killer.
Old January 24th, 2008, 12:47 PM   #17
86_Notch's Avatar
1986 lx notch
9.98 @ 135
that sort of was my point, if he moved to a windsor he could use a stock block and not have to stroke it in order to have more cubes, but he could stroke it later on and be able to gain another 50 or so more cubes
Old January 24th, 2008, 12:51 PM   #18
Goblin's Avatar
88mm
He'd gain alot more than 50hp from say 57 extra cubes. With the increase in displacement and with forced induction, i wouldnt be suprised if he picked up an extra 100hp. The 351 is a good way to go IMO.
Old January 24th, 2008, 03:31 PM   #19
1993 Mustang LX
N/A
But i want to have a efi system but will a 302 ecm work with a 351
Old January 24th, 2008, 03:34 PM   #20
Goblin's Avatar
88mm
EFI is not a problem with 351s. The stock A9L ECU will work with the 351, its all in the tune. All the EFI stuff from the 5.0L will work on the 351.. theres no magic tricks to perform.
Threads Similar to: Twin Turbo or s-trim sc
Turbo Size, A/R and Trim 2000Si General Tech 8 October 3rd, 2008 09:59 PM
Supercharger, Twin Turbo, and Single Turbo justinsstang General Tech 24 March 7th, 2007 10:07 PM
Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 Mellon Videos 10 December 30th, 2006 11:05 AM
Turbo, Twin Turbo, Procharger, or Kennebell? black94gt 5.0 Mustangs 19 October 7th, 2006 11:41 AM
Super Charger vs Turbo/Twin Turbo: Pros and Cons of each FireryDriver 2005 - 2010 9 September 17th, 2006 05:15 PM
