top starter bolt question.....
I am trying to remove the top bolt on the starter. The last person that put the starter stripped the top bolt. I tried using the extractor sockets and they just keep shaving the bolt head. Other than removing the motor.....what are my options..thanks.
Pat |
#2 | |
1992 LX 5.0
Good luck, that one was a SOB Last edited by Devine; January 24th, 2008 at 11:13 AM. |
You could drill the head off (starting with a small drill bit and getting larger each time), another method is a quick solid blow with a cold chisel and a hammer (chilling the bolt helps), or a combination of both things. Don't know if you have room in there to do this though. Once you get the starter out, a stud extractor can be used to get rest out.
1988 lx
9.68@142
get a wrench u dont care to waste and weld it to the bolt to break it loose then grind it off then use vice grips.. pb blaster the shit out of it too
another possibility is to use a mapp gas torch and burn the head off to remove the starter and then use a bolt extractor once you have more room....or you can just screw it forward out the other side.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
thanks for the replies guys....going to try all methods till it comes out.
pat |
#7 | |
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
Threads Similar to: top starter bolt question.....
| Starter solenoid clicks at the starter but wont start the car?? | 95StangSVT | 94-95 | 13 | March 11th, 2010 10:22 PM |
| Starter Top Bolt...... | lwhitetrash88l | 5.0 Mustangs | 8 | May 31st, 2007 10:52 PM |
| starter solenoid question | fastford3388 | 5.0 Mustangs | 2 | April 23rd, 2007 10:40 PM |
| Starter Question/ Problem (Heat Soak) | xjer88 | 5.0 Mustangs | 13 | March 7th, 2007 10:55 PM |
| Starter mods and Bolt ons | itschristorres8 | V6 Mustangs | 14 | March 6th, 2007 05:17 PM |
