What RPM Should I Launch At Drag Strip?
i have a 92 notch with a 3550 tremec,373 stock 8.8,trichflow rseries intake,edlebrock perfromer heads,compcam 512 lift 230 duration,1.6 roller rockers,190 pump,spec stage 2 clutch,24 lbs injectors ,prom meter,msd 6al with 6000 rpm pill,full mac exhaust,also running et drag slicks and draglites skinnies up front.
car weighs 2850 and i'm guessing about 300-310 rwhp maybe? this car should be a high 12 low 13 car i'm hopeing........what do you guys think? should i launch at rev limiter or 4000 rpm ? dump clutch or let out slower? new at this so i wanna do it right......... |
Launch it right off the limiter at 6000 and power shift the tar out of it.
#3 | |
11.47@120.58
#4 | ||
RLY SRS
11.21@123 -150 shot
![]() iTrader: 1 reviews
Nothing like launching while bouncing off the limiter.
Moderator
i say limiter launch it also, youll get a few good passes out of it before you have to say peace out stock axles
There's a reason Ford codenamed them the Terminator
Let'r eat off the rev limitor...
They make new axles every day
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
what kind of rear wheel hp should i have and what do you guys think my times will be???
The axles will hold up for a while. I launched at 6000 rpm on small slicks with a stock T5 and stock axles and just over 300 hp at the wheels for a whole season without breaking anything.
burn that cluch up baby
well shit this town aint big enuf for the both of us |
Why wouldn't you want to roll off the line at 4500 or so to prevent loss of traction. If you have enough low end torque you should be able to beat a similar vehicle that spins it's way out. Comments? Thoughts?
It will be cool to launch at 6000rpm's but you will have a hard time launching like that... I would start low (high 2's) and see how high you can get it. I think you should set your psi also around 16psi.... maybe lower if you can.
![]() 93 GT - Full Exhaust, 3.90's, Front Tubular Suspension, etc. 88 GT "Big Blue" - Body work & primer! |
He has slicks. He will have no traction problems. Run them at 11-12.5 psi and launch at 6000 rpm. Hold on tight.
Threads Similar to: What RPM Should I Launch At Drag Strip?
| Drag strip suspension | AggieStang | General Tech | 2 | October 24th, 2007 05:12 PM |
| Drag Strip | blkONblk02GT | Drag | 2 | October 8th, 2007 08:37 PM |
| went to the drag strip for some fun. lol boy did i have it. | Timmano | The Clubhouse | 13 | June 11th, 2007 12:55 AM |
| Going to drag strip next weekend | Timmano | V6 Mustangs | 18 | May 10th, 2007 01:36 AM |
| drag strip tires | militarygt | General Tech | 20 | March 4th, 2007 09:41 AM |
