Heater takes forever to produce hot air
Anyone know how or why this is happening. I just put a new thermostate in the thing the other day. Still takes forever for hot air to come out. It does get hot but takes about a 1/2 hour of driving. Then I'll finally get some hot air going.
1989 mustang GT 5.0
Thermostat stuck open im in the same situation right now. just havnt gotten around to fixing it.
#3 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
get your cooling system flushed, could be a clog not letting fluid flow through the heater core. I just replaced my therm too and it helped a little but still takes some time. also what temp did you go with?
1992 Lx
11.39@119.24
the block and heads are cast iron, takes them awhile to heat up
its not the heater core he said it takes 1/2 an hour for his engine to get to normal heat range. im betteing the new one is either opening to soon or its bad too.
I went with a brand new 192 factory Thermo. It's been on the car as of the last week in Dec 2007. I put the spring side into the intake. Hope I got that right.
Other thing is when I first start up the car. I can hear the water flowing thru the heater core. Isn't that wierd.
1989 mustang GT 5.0
#7 | |
another thing i should mention. Sometimes and it didn't do this before I put the new thermo in. My temp gauge will sky rocket to around 220 with very cold air blowing then I'll turn it off then the temp will drop very fast to normal range I'll turn the heater back on and I'll have warm air. Wish I could show someone. Everyone thinks I'm crazy but it really does happen. Not all the time but it has happened a few times.
1989 mustang GT 5.0
#9 | |
1965 Mustang Fastback
do you personally know this guy?
I'm a good boy now. [COLOR=red][B]slow car club - crew member 7 of 9 [COLOR=White]Mood: Cool :cool: [/COLOR][/B] [/COLOR] |
you have the spring facing the engine then that is correct.
#12 | |
#13 | |
A wa???????
1989 mustang GT 5.0
take the thermo out and see if its stuck open and do the boil test to verify it functions in its correct range and not opening to soon.
#15 | |
1990 LX hatch
You prolly have alot of air trapped in the engine, just keep topping off the rad.
Threads Similar to: Heater takes forever to produce hot air
| AC & Heater now that it is winter, my heater doesn't wor | Kingcater | 5.0 Mustangs | 13 | January 22nd, 2008 12:33 AM |
| Heating Takes Forever | dr.gonzo! | 5.0 Mustangs | 16 | November 21st, 2007 06:59 PM |
| Which Subs do I get and produce the best quality? | Stagray | Audio/Video | 20 | September 25th, 2007 12:24 AM |
| Finally !!! March 15th seems forever ago !!!! | MeZ | 99-04 | 6 | May 12th, 2007 08:17 PM |
| Goodbye Forever MM | Texan_Stud | V6 Mustangs | 28 | February 6th, 2007 01:06 PM |
