C/R ratio
Old January 24th, 2008, 04:30 PM   #1
viper3508 is on a distinguished road
C/R ratio
Hey guys I need some advice...
I am being told by mutliple sources that running my KB 6.8cc pistons on GT-40 heads with a standard fel-pro HeadGasket is going to create to high of compression to run JUST 93 octane for a daily driver. At the sametime I have a few others saying that it can be done.... can anyone clear this up for me?
Old January 24th, 2008, 04:51 PM   #2
woody1 is on a distinguished road
Bore size? 4.00, 4.030, 4.040 etc
6.8cc dome?
CC of the head
what is a standard fel pro head gasket? .041, .047, .039??????
Deck Height? .010 in the hole, .020 in the hole etc etc ???
Old January 24th, 2008, 04:56 PM   #3
6.8cc dome piston
Gasket= 4.145" bore, .04" compressed thickness (or-8.7cc)
pistons and block are top decked (piston is .0" deep)
they are IRON gt-40s as well.
Old January 24th, 2008, 04:58 PM   #4
Originally Posted by viper3508 View Post
6.8cc dome piston
need to know combustion chamber size, they vary greatly regardless of ford published numbers, also need the bore size
Old January 24th, 2008, 05:06 PM   #5
61cc head, 4.030 bore, stroke 3"
Old January 24th, 2008, 05:09 PM   #6
10.9 and you will have trouble on 93 with that iron head. Is the dome hollow or solid? If solid, depending valve relief depth, you can mill the dome. And no moving to a .060 gasket wont help, it will help in terms of static cr, but .060 quench is a no-no
Old January 24th, 2008, 05:27 PM   #7
well I dont really know what a quench is... however, the dome is solid as far as I know.
Threads Similar to: C/R ratio
FMU ratio? ryans88gt 5.0 Mustangs 18 January 16th, 2008 09:32 AM
4:10 gear ratio sugarfree V6 Mustangs 81 September 24th, 2007 10:41 AM
Gear ratio 1BADSTANG 5.0 Mustangs 13 September 17th, 2007 10:27 PM
compretion ratio whitemustang02 V6 Mustangs 51 September 7th, 2007 11:55 PM
compression ratio mustangrebuilder Classic Mustangs 13 August 14th, 2007 10:08 PM
