1989 mustang LX
11.42 @120
Limited slip
Looking to put a limited slip back in my mustang but dont want to spend 500 dollars yet because im going to put a lockr in it sooner or later but Ive eard that a limited lip out of a ford F150 would work but im getting two different part numbers S824A and S825B does anybody know what these part numbers are and also will that limited slip out of a ford F150 work thanks.
89 hatch.....4,000 dollars..vortech supercharger kit.....3,800 dollars...built 306 windsor motor.....3,000 dollars beating a 75,000 dollar z06 corvette....PRICELESS UNTIL I SOLD THE CAR |
1992 LX 5.0
not sure on the F150, but you can pick up an 03-04 Cobra limited slip for around $299 (it will require you going to 31spline axles though)
people have done 9 second passes with stock cobra diffs |
1990 LX hatch
your car should have one in it.
The Razor's Edge
T-lock playa
1989 mustang LX
11.42 @120
I believe my limited slip isnt working properly whenever i do a burnout the right tire turns but the driver side barely turns. doesnt turn enough to warm it up. so i was told that meant it was broke.
1990 LX hatch
$50 ebay rebuild kit. It takes about 45minuts do install. No taking the carrier out, or anything.
you can get one from fordracing for 50 bucks and they have a carbon disc rebuild also but its about 110......most likely the clutches are just worn out rather than it being 'broke'
Big timin' in a small town
Yep your clutches are just wore out no biggie. By a clutch rebuild kit I got mine from these guys
Latemodel Restoration Supply - America's #1 Restoration and Performance Parts Warehouse
1989 mustang LX
11.42 @120
Thanks everyone you just saved me a bunch of money.
no problem
1989 mustang LX
11.42 @120
you guys were right the clutches were all messed up there was only one that was grabing. hopefully by replacing these it will help drop my 2.2 60ft time
you can stack four clutches in each side and leave out a spacer to really make sure you put it all to the ground
94 GT
What's better limited or the stock limited with some lockers?
94 GT - Deep Forest Green Off road X, flowmaster single chambers, typhoon intake, hurst short throw, CAI, eibach sportlines, 315s, foxbody short block ![]() |
If you put new clutches in stock or carbon with I reccomend it will still be a limited slip meaning you take a curb and one side will "give" alittle so you don't cause stress to the drivetrain if you have the extra cluch (4th) it will lock up more like a spool if your going serious street / strip car I would reccomend this route if it's more of a dd I would say just do the rebuild and use the three clutches in the kit even the stock rebuild kit will solve your one wheel peel problem
#15 | |
12.9 @ 105
it may "bark" alittle going around tight curbs but it's not gonna hurt the car
1986 lx notch
9.98 @ 135
it will be fine, my buddy replaced the clutches in 2 different cars for me and put in the extra clutches, just remember to add the friction modifyer when you refill the diff with gear oil
so the friction modifier is what makes the regular gear oil work with a limited slip right?
1986 lx notch
9.98 @ 135
i don't know what it does, i just know that trac locks are supposed to have it
hey 86 notch what do you have done to run that fast? shoot a pm if you want
Threads Similar to: Limited slip
| Limited slip | 90 Lxer | 5.0 Mustangs | 22 | January 18th, 2008 01:01 AM |
| Rumors (Limited Slip) | mustangman03 | V6 Mustangs | 15 | September 2nd, 2007 06:48 PM |
| limited slip? | cpork | V6 Mustangs | 7 | May 9th, 2007 03:36 PM |
| limited slip differential | burlingtonNC98GT | 96-98 | 6 | April 17th, 2007 01:54 PM |
| Limited Slip | JRubin2000 | 99-04 | 6 | September 21st, 2006 05:59 PM |
