massive t5 problem!!!
ok so me and my dad rebuilt my t5 and we hit some snags. when you wathc this rebuild vid we got the guy takes the tailhouse case and pushes it flush witht he main case. on our we cant do that so we have to bolt it on and it draws it to the main case. however when we do that everythgin freezes up. the shafts should spin freely and easily and you should be able to shift throught the gears but we cant. its wierd its like its stuck somewhere. when the case is off thos everythgin is free and you can move the shift shaft and go through the gears but when the tailshaft housing is on you can. its the wierdest thing ever. theres no spacers in the input housing thing were the race is cause we thought that might be the prob but it isnt. can anyone help me out here. im super frustrated and i dunno what to do!!!
post the video
What is in the way of the tailshaft...that is your problem. Are you going with a larger 5th gear, like a 0.70 or something. If so you have to have the tailshaft machined with a larger gear pocket. Also, it could be the offset shift linkage binding up, does it move freely?
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1990 LX hatch
Sounds like 5th is dragging on the tailhousing? what is the 5th ratio?
everythign moves freely. im using the stock gear that was in the trans when i got it. when i got it everythgin ran fine except the synchros were bad. anyway when i put the tailhousing on it all moves freely up until the point where the top o-ring hits the top of the shiftplate thingy. like theres about a 2cm's in between the tailhousing and the main case. from there when you go to bolt it in to draw the 2 togehter thats when the binding happens. this is the only thing we cant figure out. everythgin else works perfect everythgin moves and works how its supposed too. this is the only thing hangin me up.
You shouldn't have to use the bolts to draw it together. Find out what is keeping the two pieces from coming together...that is your problem. Check the bushing in the tail housing. Maybe use some white paint to findout what is touching the tail housing and causing the interference.
k thanks ill give it a try. its so weird cause the only thing that could bind it up is the 5th gear or the shaft that holds the fork for the 5th gear. ill try and figure it out omorrow. thnks for the help
sounds like to me when you put the shift fork plate back on that you had the transmission engaged in 2 gears instead of neutral. Had this happen once.
1986 Mustang GT t-top time piece! |
1988 lx
9.68@142
no it sounds like tthe rear bearing race isnt pushed in all the way before u put the tailshaft housing on that tace needs to be all the way in with no movement of the shaft..
1988 lx
9.68@142
it could actually be a few things.. the race could not be in all the way when u install the rear case..
when your putting the rear case on it could be going into gear but also if u put new blocking rings on they could be getting pressed in tight and when it is not spinning it will feel like it is locked try to put the clutch disk at the end and turn real hard is should break loose and spin freely... mine did the same yourse is doing..
I would think one of the fifteen rollers in the input shaft has dropped pushing the output shaft too far back. You'll likely have to pull it back apart and see what's out of place.
BadShoe Productions, How-To-DVD's specializing in Ford drivetrains www.BadShoeProductions.com |
Threads Similar to: massive t5 problem!!!
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 01:03 PM |
| Oil Problem? | RC02GT | 99-04 | 5 | November 18th, 2007 01:48 AM |
| problem | ebo 4356 | 96-98 | 10 | October 24th, 2007 07:53 PM |
| Name three songs that invite a massive speeding ticket | WAR-PARTY | The Clubhouse | 50 | May 31st, 2007 08:07 PM |
| Oil problem | AndoGT | 99-04 | 9 | November 29th, 2006 01:28 PM |
