2001 Mustang GT
Built
What kinda power could you expect out of a built 5.0? I'm more into the modulars put i like the 5.0 sn95's alot and was thinking about maybe getting one in the future. Anyone got any idea on what kinda n/a power i could build to and how much it would run me? Haha know this is kinda vague but i'm just trying to get an idea
![]() SLP cat-back, Steeda short throw, MAC cai, FRPP 3.73 gears, 20% tint, Mach 1 grille delete, Mach 1 chin spoiler |
2001 Mustang GT
Ok well if anybody has any advice, I'm not real familiar with the 302's but any ideas are welcome you can post or PM me. Once again sorry it's so vague just looking at what kinda numbers i may could expect at the best cost.
so how much you looking to spend, or how much hp do you want
'88 Mustang GT, Long Tube Headers, Off Road H-pipe, Flowmasters w/turn downs, K&N, Under Drive Pullies, Smog delete/Ac eliminator/72" belt, Subframe connectors, 3.73 Gears '93 LX 4-banger 78k miles |
1987 Mustang GT
Could do 400 n/a rwhp with a nice stroker, not exactly sure of the price but chp has a bunch of short block kits or dss
2001 Mustang GT
I'm not sure really i was hoping around 300rwhp what do you think that'll run me? I know rebuilds can get high but i want it to be cost efficient
2001 Mustang GT
This is just an idea right now by the way I don't have a car yet i was just looking at some possibilities.
300rwhp can be done with just bolt ons, and a stock shortblock.
2001 Mustang GT
Really? I'm not real familiar with the 302's thats why i have an obvious lack of knowledge. If i decided to do this and wanted to rebuild with bigger cams what would be the best setup i mean should i go with higher compression pistons and port and polish the heads or what?
302s only have one cam. An H/C/I swap, leaving the stock shortlblock (with its pistons), bigger fuel pump, injectors, adjustable fuel pressure reg, MAF, throttle body, a good set of long tube headers and free flowing exhaust, all with a good tune... 300rwhp would come easy. Other simple stuff like UD pulleys, or A/C delete, smog delete... PS delete.. Every little bit will help. 300rwhp has been done by so many people with just bolt ons.
2001 Mustang GT
Ok lol i didn't know that aren't they in the low 200's stock? What cost you think im looking at there also? Including labor on the cam swap
2001 Mustang GT
And since I'd be looking at all the motor work anyway would there be a real advantage in looking at a 94-95 cobra over the gt?
$3500-4000 i would say is a reasonable budget for 300rwhp. All the bolt-ons you would need for that performance could be performed in your driveway, including the cam swap. The 94-95 Cobra has a better intake, cam and heads from the factory.. but because you'd be swapping to a better intake, cam and heads anyways, buying a GT is probably better money spent in the end.. simply because GTs are cheaper than cobras.
2001 Mustang GT
Ok man I appreciate it. If I decide to do it later on down the road I'll let you know how it goes
Right on man. Keep us posted!
to add a piece, i would do a custom grind cam last
#16 | |
13.64@101mph
and the stock block
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come |
1986 lx notch
9.98 @ 135
can't he get a trick flow or systemax top end kit and make 300 hp or so for like 2 grand ??
13.64@101mph
$2500 he can get trickflow's set-up and make about 350hp to the crank..but i've seen more around 325hp...swap out that cam and rocker arms with custom cam and crane or harland sharp roller rockers and your more likely to make 350hp+
Threads Similar to: Built
| Built Motor | usafimj | 2005 - 2010 | 47 | December 15th, 2007 06:07 PM |
| 460 vs Built 5.0 | 83five0 | 5.0 Mustangs | 50 | December 2nd, 2007 12:45 AM |
| Built AOD | RandoGT | 96-98 | 2 | October 22nd, 2007 06:48 PM |
| Built 2v vs 4v | banned | 99-04 | 9 | September 15th, 2007 01:29 AM |
