shaving heads
Old January 26th, 2008, 09:23 PM   #1
dadslx is on a distinguished road
shaving heads
stupid question but right now im running a c/r of 9:1 i want to achieve 11:1 if i shave my trick flow heads can i achieve that?
Old January 26th, 2008, 09:24 PM   #2
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Dont think so. Need different pistons
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old January 26th, 2008, 10:13 PM   #3
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
you cant pick up that much by milling the heads
Old January 26th, 2008, 10:34 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I think a standard Twisted Wedge head can be milled to 48cc safely but you would have to contact Trick Flow to be sure. At 49cc with a stock short block and a .040 x 4.100 head gasket you are looking at about 10.99:1 compression. Its not going to gain you much over the 9.3:1 the 61cc chambers will give you. There are people making big horsepower with stock compression. I'd be looking at other areas to gain more horsepower before I'd mill the heads that much.
Old January 26th, 2008, 11:11 PM   #5
1987 ford mustang gt
well see when shes done
this sounds like a good time to think about a turbo.
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old January 27th, 2008, 12:18 AM   #6
ryans88gt's Avatar
That's angle milling right? I would imagine that would make one side of the deck sealing surface very thin and cause all sorts of other issues like requiring milling of the intake and poor distributor gear mesh.
Old January 27th, 2008, 09:20 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I am assuming that he has Twisted Wedge heads and I'm also going to assume that is flat milling because you can more volume per amount milled. I could be wrong but this is Trick Flow's specs angle mill .008" per cc; Flat mill .006" per cc. I've never milled a Trick Flow head down to 48ccs but everytime I've ordered a ported head they've asked me what size combustion chamber I wanted and 48cc was always the smallest for Twisted Wedge and R-series heads.
Old January 27th, 2008, 10:39 AM   #8
jam77's Avatar
1987 Mustang GT
just add a s/c or turbo or maybe n2o and be done
Old January 27th, 2008, 12:31 PM   #9
Well i should probably tell you the rest of my combo. im running a 347 stroker forged bottom end, tfs t/w heads ported, systemax intake. i built the motor with a supercharger in mind but that would pretty much kill the block. if i did decide to brave it and run a power adder i most likely would go turbo for the unique build...just for shit and giggles has anybody ever ran a kenne bell 2.2 supercharger with a twin turbo setup?..i was laying in bed last night thinking that a 5.4 with a twin charger would be pretty kick ass...and would a supercharger off a thunderbird super coupe mount up to a 5.0 block??..found one for 150 that ported off my friends blown engine.
Old January 27th, 2008, 12:47 PM   #10
ryans88gt's Avatar
I saw an article in MM&FF with the twin turbo cobra motor with the eaton still on there. Made 44 PSI and 1100 HP.
Old January 27th, 2008, 12:55 PM   #11
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
yeah i seen that......they said it would have actually made more peak horsepower if the sc would have been replaced with a cobra intake.....but they said with the sc it made a really great torque curve
Old January 27th, 2008, 01:43 PM   #12
thats just nasty..wonder how a boss block would hold up to a setup like that..cause i may just doing that here with next years taxes (2009) but it would be a 347 stroked twin charger
Old January 27th, 2008, 01:46 PM   #13
1990 Mustang GT
well i think the boss block is rated at 1200 horsepower right?......if you were really lookin into something that extreme you might as well go ahead with a dart or world block
Old January 27th, 2008, 01:54 PM   #14
baine21225's Avatar
i did't know they were rated that high
Old January 27th, 2008, 01:55 PM   #15
1990 Mustang GT
i might be wrong
Old January 27th, 2008, 02:27 PM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Well that changes everything. Are the pistons flat tops or dished pistons? With flat top pistons, 61cc chambers, 0 deck, and a .040 x 4.100 head gasket you are looking at about 10.75:1.
Threads Similar to: shaving heads
10 tips for shaving ET this weekend TurboLX Drag 30 June 23rd, 2011 12:20 PM
Milling / Shaving The Head hellion_79 2.3 Mustangs 12 November 17th, 2007 12:42 AM
RHS heads , are they good cylinder heads? hitorx 5.0 Mustangs 25 May 12th, 2007 09:55 PM
Cylinder head shaving acmillr 99-04 1 January 8th, 2007 10:34 PM
Boss 302 Heads Same As Cleveland Heads? ken5_0 Classic Mustangs 8 September 25th, 2006 03:18 PM
