Performance Alignment
OK, time for the first alignment since I have put this monster together.
I have heard that there is something called a performance alignment. I saw someplace where you do not use the factory specifications, but you use negative .5 to negative .2 degrees for the camber, and 1/16th toe in. Has anyone done this? If so are these the correct numbers? Does this make your tires wear faster? The last thing I want to do is buy tires sooner than normal. I have asked a few shops, and they basically tell me they will not be responsible for pulling or tire wear if I do anything other than the factory specifications, which I understand. Thanks, Robert
"Those who forget the past are condemned to repeat it" Rev. Jim Jones |
1999 Ford Mustang V6
I would sugguest the following:
1979-93 Toe In: 1/16" Camber: 1° negative Caster: 2° positive 1994-2004 Toe In: 1/16" Camber: 1° negative Caster: 2.5-3° positive you will be fine on tire wear as long as you rotate like needed, but ofcourse harder cornering will wear the outside of the tires faster. some places don't know how to handle adjusting aftermarket c/c plates so follow the attached illustration
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
Threads Similar to: Performance Alignment
| Alignment issue | OKC Drift | 99-04 | 5 | August 5th, 2007 06:22 PM |
| How much for total alignment? | nba1341 | Classic Mustangs | 14 | July 30th, 2007 07:03 AM |
| Lowering and Alignment | axon360 | General Tech | 3 | March 11th, 2007 03:41 PM |
| Alignment settings | Stangzilla | 5.0 Mustangs | 11 | March 4th, 2007 09:50 AM |
| Alignment | rene9 | 96-98 | 3 | November 10th, 2006 12:55 PM |
