Supercharer Requirements?
hi..
i was going to go for either a 331 or a 347,but,,i've decided to go with a vortech s-trim instead and keep my 302.I have a 75mm mas with 24# injectors.would that be enough supprt for 8-10 #'s of boost? thanks steve |
What else is done to the engine? For comparison purposes a friend of mine runs 42lb injectors with 10lbs of boost on his 302. He is making about 600 at the wheels.
Hi,, ordered my s-trim today,,,,
the car has gt40p heads,b303 cam,cobra upper and lower, long tubes,msd6al,walpro 255,,75 mas,75mm tb. hope this helps... thanks steve |
30# injectors, 190 LPH Walbro, 70 mm TB are very good for 6-8 lbs
for 10 lbs you need to upgrade your injectors to 42# with that 255, get a Pro-M calibrated.. MSD BTM is definitly required.. and keep the static compression low but not lower than 9:1 |
well,,,ordered my new maf and 42# injectors,,,
next is a anderson power pipe.So if all goes well.The Notch will Be "force fed" very soon
Threads Similar to: Supercharer Requirements?
| Requirements for installation of new ring and pinion gears? | shurb125 | 5.0 Mustangs | 6 | February 17th, 2007 11:12 PM |
| Requirements For A Hand Held Programmer | khartford | 99-04 | 1 | September 19th, 2006 04:19 PM |
| Requirements for 347 stroker in an Auto tranny 95 GT | Zak | 5.0 Mustangs | 3 | August 17th, 2006 06:37 PM |
