400 motor
Old January 30th, 2008, 08:53 AM   #1
Divan is on a distinguished road
400 motor
Does anyone have a 400 c.i. motor for a 1982 Ford F-250? My friend is in desperate need of one for cheap.
Old January 30th, 2008, 12:04 PM   #2
The Razor's Edge
White Thunder's Avatar
google buddy.....get a 351
founder of the FTN Club
Old January 30th, 2008, 02:51 PM   #3
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
All 351's arent the same as a 400. You need a 351M block out of a truck. The only difference between the two is the 400 has a longer crank and biger bore
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old January 30th, 2008, 07:56 PM   #4
The Razor's Edge
i was just saying its easier to find a 351.....and start there but thats for helping me out bro
Old January 30th, 2008, 08:32 PM   #5
86ttops's Avatar
86,97 mustang gt t tops
n/a
86ttops will become famous soon enough
Send a message via Yahoo to 86ttops
I would just put the 351m in it better on gas
Old January 30th, 2008, 10:35 PM   #6
p-351's Avatar
90&94 GTs; 79&91 Broncos
p-351 is on a distinguished road
Finding any "good" (no rebuild required) Modified is getting hader and harder to find. I wouldn't be too picky if I was looking in the wrecking yards or classifieds for a good M. As for the "better on gas" statement I have to laugh-------because you have "No replacement for displacement" in your sig
White Thunder, I haven't been on this board too long and I don't know you that well, but do a little bit of research before you give out advice--or clarify your statement. By saying to find a 351 because it is easier I assume that you're referring to a Windsor--because they are easier to find than any Modified nowadays. The Windsor has a small block bellhousing bolt pattern, whereas the Modified (351 & 400) have a big block bolt pattern--making it necessary to change transmissions as well.
-Divan, as for finding a good Modified I wish I knew where one was (because it would be in my 79 Bronco). It might be easier for your friend to find a good 460 and put that in his F-250. They put those in until 97---Modifieds I believe died out in 82.
Old January 30th, 2008, 10:48 PM   #7
86ttops's Avatar
n/a
well i just ment its a truck when it comes to a stang who care bt something you have to drive everyday
Old January 30th, 2008, 11:38 PM   #8
p-351's Avatar
I figured that, I just thought I would point out the irony in the post
Old January 31st, 2008, 05:15 AM   #9
The Razor's Edge
im here to learn like most of the people....and i learn a few new things a day....thanks for not being a dick....now i know....still might be easier to find a 351W and trans......you don't see many 351M's around
Old January 31st, 2008, 09:53 PM   #10
Thanks for all the help guys I found a motor from another guy in my neighborhood luckily. It is a 400 he had in storage for about 5 years and it has 78,xxx miles on it. Feels good to help out.
Threads Similar to: 400 motor
How much boost can you put on a stock 4.6 v8 motor with out mesing up your motor? Jonathan General Tech 3 January 2nd, 2008 09:34 PM
Motor For My 69 Mike's 69 Classic Mustangs 10 November 29th, 2007 08:52 PM
need some help american motor to import motor wadepetersen V6 Mustangs 29 May 30th, 2007 09:26 AM
How do you find the motor code on a 88 5.0L motor? semihemi428 5.0 Mustangs 1 March 16th, 2007 04:56 PM
