Discussing electric fan install help in the 5.0 Mustangs Forum. went to the junkyard today to find an electric fan, i found a newer, like ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
91 mustang
266 ftlbs 191 hp (15.138 @92.91) @5000ft elevation
went to the junkyard today to find an electric fan, i found a newer, like late 99 or early to mid 2000 import with some really slim dual 10" system and figured those would work great, so here i got them home and pulled took off the plug in for the factory system, there were only 2 wires i figured easy, power and ground, black would be the ground, then there was a blue wire and now im confused as to weather that is poer or something else, wt can u guys add?
![]() Fender well cold air intake, 3:73's, eibach springs, 65mm TB, electric fans, 3g upgrade, smog delete, advanced timing, MSD cap and rotor, ford racing 9mm plug wires, 75mm Pro-M MAF, flowmaster sieres 40 delta flows |
1988 lx 5.7
11.6@109
power could be alot of differnt colors..black is always groung.. if there is only 2 wires u can switch them to change the poliaritys and it will change which way the blade will spin.. just hook it up to a battery to see which way u want ti to spin..
the only thing u will be burning by going with a 347 insted of a 331 is the guy driving the 331 MILITARY CREW USAF LUKE AFB AZ, E-5 SELECT 7995 AMMO I.Y.A.A.Y.A.S |
91 mustang
ok i did and there only 2 wires, blue and black, and it works but it seems like, how can i say this...... it leaves marks on the battery terminals
91 mustang
91 mustang
ne body? i even put up pictures of the fan
sounds right, some electric fans pull 15 AMPS, which is a lot. Wire up a relay and a thermometer switch and you'll be set.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph 88 GT 11.4 @ 118
91 mustang
well i just picked up a switch before i got ur post but wt if i wire a 20amp fure onto it?
You have to run a relay. Use the switch to activate that relay, if you wire it straight from the battery to the switch and then to the fan you will overheat the switch, possibly cause a fire.
91 mustang
that would be awsome wouldnt it, ok so do i just need a generic relay or?
91 mustang
that fan looks small. I hope it pulls enough to keep ya kool.....
Rotating The Earth 1320 Feet At A Time!! The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” |
mystery heads?
I have a friend whos son has a Mustang and they are pullin it apart to make sure everything is kosher. I have a head question. he said after removing the intake and inspecting the heads everywhere he cannot find no signs of what kind of heads they are. they are aluminum and all he can notice is by using 2 mirrors up under where the intake would mount between cyl 3&4 and on the other side between cyl 5&6 there is the number 9035. besides that he said there is 2 header bolt holes on each side of the port, so each exhaust port has 4 holes. Can anyone give an idea to what heads these might be?
91 mustang
well theres 2 fans its a dual fan system, and wt about the feakin relay?
#14 | |
What about it? I would say to be safe get a 30a relay. Because you have a relay that allows you to use a low current switch. thats it..
1988 lx 5.7
11.6@109
relays are cheap and easy to use just go to home depot and get one..
91 mustang
home depot? ok thnx i was just abot 2 go down to the auto store, thnx a lot guys, ill take pics of it today once i get done if ne one cares
91 mustang
bumpin to the front
Threads Similar to: electric fan install help
| Electric Fan? | JONJON | 5.0 Mustangs | 7 | December 1st, 2007 03:05 PM |
| Electric fan | Pony_with_an_attitude | 5.0 Mustangs | 12 | April 8th, 2007 08:45 AM |
| electric fan | hmotes | 5.0 Mustangs | 5 | January 14th, 2007 08:23 PM |
| Electric Fan | shadowgames81 | 5.0 Mustangs | 5 | December 21st, 2006 12:34 AM |
| help electric fan install | fakesaleen | 5.0 Mustangs | 5 | April 27th, 2006 05:24 PM |
