How To Fix Detonation
Old September 22nd, 2006, 01:26 AM   #1
slingblade05 is on a distinguished road
first of all what is detonation lol?
and how to fix it lol
1991 mustang
Old September 22nd, 2006, 01:34 AM   #2
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
well first off...those are really good questions lol i'd like to know too ..
[SIGPIC][/SIGPIC]
Acmillr loves me
Old September 22nd, 2006, 01:42 AM   #3
DaveT is on a distinguished road
usually knocking back timing wll stop detonation also using higher octane gas will help and if the car has knock sensor it should autatically knock back timing to prevent it and if your car has one (I am not usre if it does) it may be bad
a friend once told me, procrastination is like masturbation, they both feel good until you realize you just f**ked yourself
Old September 24th, 2006, 01:39 AM   #4
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
right. either pull some timing or use a higher octane number. if you hear what sounds like marbles in a tin can, its detonation. next comes a broken piston lol
Old September 27th, 2006, 10:18 PM   #5
Zak
Zak is on a distinguished road
lol
Old September 28th, 2006, 11:52 PM   #6
88BlueGT is on a distinguished road
Send a message via AIM to 88BlueGT
+1 Try running a higher octane and see if that helps. If not, than lower your timing and you shouldnt have any problems. What I would do is run 91 octane. Drop your timing to 10 degrees and see if it pings (it definetly shouldnt though). Than work your way up one degree at a time until it starts to ping. As soon as you hear pinging knock it back one degree and set it there. This whole process should take 10 mintues and possibly save your motor.
93 GT - Full Exhaust, 3.90's, Front Tubular Suspension, etc.
88 GT "Big Blue" - Body work & primer!
Old October 11th, 2008, 11:48 AM   #7
interfac9's Avatar
1999 Mustang GT
interfac9 is on a distinguished road
Send a message via AIM to interfac9
What about negative timing? Can it cause detonation too?
1999 Mustang GT, 247.7 RWHP @ 4400 RPM - 300 Ft/lbs TQ
Roush CAI, UPR TB Spacer, MAC O/R H-Pipe, Flowmaster Catback,
4.10 Gears, Centerforce Stage II Clutch, Bilstein Shocks & Struts,
H&R Springs, Roush LCAs, Mach 1 Grill Delete
Old October 11th, 2008, 11:59 AM   #8
1998 Cobra
13.24@105.66
if timing was that far out, it would run like total ass and not even get a chance to detonate.
if your car is detonating, and you have a working knock sensor...
1) air fuel is too lean -
Culprits -
Clogged Fuel strainer on the pump
Weak fuel pump
Low voltage to fuel pump
Clogged fuel filter
dirty injector
Fuel pressure low
Fuel leaks
Maf signal is dirty
Maf ground is dirty
vacuum leaks
2)Timing -
Culprits -
Timing too far advanced for octane
Base timing incorrect
Coolant temp sensor malfunction
cam timing incorrect
weeee foooord!
Old October 11th, 2008, 12:04 PM   #9
interfac9's Avatar
1999 Mustang GT
any way to test the knock sensor? I have no codes. I run Amoco Ultimate religiously, 93 Octain, wit the SCT Tune backed off 4 degrees in all three ranges. Got on it on an onramp this morning and got marbles... c My 4D has been on me about the pinging for a while, and it comes and goes, an not consistent with new tanks of gas.
Old October 11th, 2008, 12:05 PM   #10
interfac9's Avatar
1999 Mustang GT
base timing adjustment... How? I don't know the OHC motors.
Old October 11th, 2008, 12:06 PM   #11
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
What plugs you running brotherman and what gap?
Facebook
Google+
Old October 11th, 2008, 01:18 PM   #12
1988 Mustang
88Saleen is on a distinguished road
Send a message via AIM to 88Saleen
just wondering what all your guys were running for timing? stock is 10 degrees advanced correct?
Old October 11th, 2008, 01:21 PM   #13
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
1991 mustang
add more timing j/k
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old October 11th, 2008, 02:37 PM   #14
interfac9's Avatar
1999 Mustang GT
Last change was to Motorcraft iridiums with stock gap. Usually use copper but figured I would try out the iridiums.
Old October 11th, 2008, 02:38 PM   #15
interfac9's Avatar
1999 Mustang GT
I didn't know stock timing was that advanced on these cars...
Old October 11th, 2008, 02:40 PM   #16
fateisajester's Avatar
1989 Ford Mustang
3 mins
fateisajester is on a distinguished road
Send a message via AIM to fateisajester
Detonation is when your fuel is ignited before the piston has reached the end of its up stroke. Just like it sounds, detonation is an explosion in the cylinder, which is bad. A common misconception is that the fuel is supposed to explode to make the engine work. Infact, the engine turns due to an expansion of gas (similar to the way some people air up new tires by lighting eather inside it)
Old October 11th, 2008, 06:15 PM   #17
Hunt_chevs's Avatar
2002 Gt
Not Slow
i run mine at about 15*advanced
Old October 11th, 2008, 11:05 PM   #18
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
Change your plugs and set your timing around 12 dude
Old October 12th, 2008, 02:19 AM   #19
interfac9's Avatar
1999 Mustang GT
Now keep in mind I'm currently using an SCT canned tune.
12* advanced on THAT?
Threads Similar to: How To Fix Detonation
Detonation cgstarry 2005 - 2010 9 August 11th, 2007 08:16 AM
What is detonation? mustangmanic 99-04 3 July 29th, 2007 11:54 PM
Detonation and Preigntion definition shawn91stang 5.0 Mustangs 1 January 8th, 2007 01:52 AM
what exactly does detonation sound like? 97snakercin 96-98 3 July 11th, 2006 10:55 PM
BACKGROUND 0N DETONATION AND PREIGNITION IcantDo55 5.0 Mustangs 0 October 4th, 2005 12:27 PM
