is a 2 bolt main enough?
Old February 7th, 2008, 01:17 AM   #1
usmcsawgunner's Avatar
1993 Mustang GT
13.2 @98.54
usmcsawgunner is on a distinguished road
Send a message via Yahoo to usmcsawgunner
7.5L/460 "SUPER COBRA JET" - 550HP FORD RACING PERFORMANCE CRATE M-6007-F460FT [75612209289] $6,600.00
Click to enlarge
Tell a Friend M-6007-F460FT Front Sump T-pan
460 cubic inch
550 HP at 6250 RPM and
545 ft./lbs. of torque at 4800 RPM. (with headers and 850 cfm carburetor not included)
10.5:1 compression ratio (nominal)
Forged steel connecting rods, M-6200-A75
Hydraulic flat tappet camshaft, M-6250-C460
High-performance T-sump oil pan
Front sump fits most passenger cars that came equipped with front sump pan
Rear sump fits most Fox body cars
MSD billet distributor
High-flow aluminum water pump, M-8501-C460
Ford Racing "Super Cobra Jet" aluminum heads, M-6049-SCJ with Ford Racing valve train
Ford Racing “Victor” single plane intake manifold M-9424-G429
460 2-bolt main short block M-6009-E460, oil and water pumps, oil pan, flywheel, and harmonic balancer
A serious high-performance engine
Depending on your application, a different timing cover, water pump, performance oil pan and pickup may be required. See installation notes
just dosent sound right..what do yall think?
Old February 7th, 2008, 01:19 AM   #2
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
well first off you can build that much power easy without being a big block
Old February 7th, 2008, 01:23 AM   #3
1993 Mustang GT
13.2 @98.54
i kinda like the idea of a big block fox tho....and i got a whole lotta room for when this becomes a full race car....
Old February 7th, 2008, 12:08 PM   #4
The Razor's Edge
White Thunder's Avatar
i say buy as soon as you get back
founder of the FTN Club
Old February 7th, 2008, 06:52 PM   #5
1987 ford mustang gt
well see when shes done
Click to enlarge
460 cubic inch
Its a TURD!!!!
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old February 7th, 2008, 07:17 PM   #6
notchabovechevy is on a distinguished road
not to bad but 6600 could go far with a windsor 4 bolt block and a good set of heads.....maybe yates nascar heads? you can find them at nascar auctions and on ebay for reasonable prices for one of the bets ( if not the best) sbf heads out
Threads Similar to: is a 2 bolt main enough?
Vehicles 351w 4 Bolt Main Came In... lighterzen 5.0 Mustangs 3 November 20th, 2007 01:57 PM
whats the difference between a 2 main and 4 main White Thunder 5.0 Mustangs 33 September 25th, 2007 09:02 PM
4 bolt main 302 based Jared_blown5.0 5.0 Mustangs 11 August 8th, 2007 04:30 PM
is there a way to te bolt main from the year? DJKING 5.0 Mustangs 1 April 9th, 2007 04:34 PM
