Code 66
Old September 24th, 2006, 12:07 AM   #1
cali 5.0 is on a distinguished road
Code 66
when i turn my car on it tends to idle real bad when cold but if i unplug the mass air flow sensor the idle picks up and does fine, and i have a code 66 4 the mass air flow sensor. ichecked the voltage and its the same as the source... i ohmed out the mass air flow sensor and it has continuity but when i plug the damn connector back in the idle drops right back down to the point where it wants to cut off...
Old September 25th, 2006, 10:38 AM   #2
sounds like it's time to replace the maf
88 Mustang Coupe
www.rickscarcare.net
Old November 9th, 2006, 10:24 AM   #3
cptkng79's Avatar
cptkng79 is on a distinguished road
Send a message via AIM to cptkng79 Send a message via MSN to cptkng79 Send a message via Yahoo to cptkng79
how did you make out with your problem
i am also getting code 66 Please Help!!!
Old November 9th, 2006, 12:40 PM   #4
fixed it.. i cleaned it once before and the code came back so i cleaned it with rub in alcohol and a q-tip and let it air out then put it back together make sure the swers are in their pretty good. worked for me
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Threads Similar to: Code 66
code SilverGT04 99-04 1 October 18th, 2007 01:14 PM
need help with a code 1quickstang02 99-04 4 October 9th, 2007 08:08 PM
Code? jblood37 American Muscle 1 August 26th, 2007 10:27 PM
Code Help MnrlGry01gt 99-04 8 July 24th, 2007 07:52 PM
96 GT vs 64 D-code 289 MustangMatt96GT Modular Mustangs 4 January 11th, 2007 05:34 PM
