Discussing AODE Under Pressure in the 5.0 Mustangs Forum. Does anybody know if a 1995 stock AODE (max. 325 HP - 275 lb.ft) can ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
AODE Under Pressure
Does anybody know if a 1995 stock AODE (max. 325 HP - 275 lb.ft) can withstand a 347 stroker SBF with Windsor Sr. Lite heads, TFS stage 2 cam, 30# injectors, CAI and 1-5/8" shorty headers?
If you have any experience, I'd appreciate your advice. I know nothing about auto trannys. |
Maintenance Man
11.47@120.58
AODE's are fairly tough, as are most automatic transmissions. Go with a reasonably sized converter, shift kit, and trans cooler and it should live a long happy life.
I'd also install a set of red alto clutches as well as upgrade the intermediate one way clutch to the mechanical diode style and the intermediate stub shaft to the later style.
88 Mustang Coupe 2006 FFW Richmond True Street Runner-Up www.rickscarcare.net http://img146.imageshack.us/img146/2158/ricksadql2.jpg |
Yep.. got Alto Eagle high performance master rebuild kit, with TransGo Heavy Duty shift reprogramming kit, mechanical diode conversion kit for AODE.. next will get an ACC Night Stalker torque converter with 2200-2800 stall speed (think it's reasonable for daily drive) for $300 from CNC Motorsports, and an transmission oil cooler.. I need to check about those parts you just mentioned.. but would I need them for applications below 350 HP or below 400 lb.ft?
Threads Similar to: AODE Under Pressure
| AODE Rebuild.... Oh boy | Timm10221 | 5.0 Mustangs | 8 | October 24th, 2007 08:33 AM |
| AODE to C4 | r7r5 | 94-95 | 4 | June 25th, 2007 10:37 PM |
| Want To Buy An AODE From 96 To 04 | 96gt | Want to Buy | 1 | October 24th, 2006 07:37 PM |
| t45 to aode swap | 96gt | Drivetrain | 0 | October 21st, 2006 11:47 AM |
| AODE To T5 Swap | 94mustanggt | 94-95 | 2 | October 10th, 2006 11:43 PM |
