3 inch exhaust setup
Old February 13th, 2008, 01:51 AM   #1
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
My plans right now is either gona be a 408 and hopefully a vortech intercooled 408 so i am gona need to flow max air........i was plannin on BBK long tubes with 1and 3/4 primaries but i havent been seeing 3 inch H pipes......it seems like i mostly see 2 and 1/2......and good setups that you guys have in mind for this
Old February 13th, 2008, 03:50 AM   #2
p-351's Avatar
90&94 GTs; 79&91 Broncos
p-351 is on a distinguished road
I've got the BBK ceramic 1 3/4"s for my 408 and was on the fence as far as 2 1/2" or 3" exhaust as well. I have pieces for both (don't ask me why) but I'm leaning towards 3". It might be too much out of the gate--but I don't think it'll hurt me THAT much. That way when my NA 408 becomes a blown 408 I won't have to worry about that being the proberbial cork.
As far as setup goes, I plan on using a Dr. Gas 3" x-pipe, Dynomax Ultra Flow or Magnaflow mufflers, and the Flowmaster 3" tailpipes I already have.
Old February 13th, 2008, 08:55 AM   #3
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
i've got flowmasters 3 inch exhaust on my 351 and it seems to work great for me, it'll be perfect for your 408, btw it's pretty loud and won't pass inspection just a lil fyi
here's what it sounds like ( the quality isn't the greatest , shot it with a digital camera )
btw the ticking isn't an exhaust leak , it's the valves needing adjusting
http://www.youtube.com/v/HcD354133Ac&rel=1
Old February 13th, 2008, 10:10 AM   #4
1990 Mustang GT
well i dont have emissions to pass so i aint worried about that......but where can i get a good 3 inch h pipe
Old February 13th, 2008, 10:32 AM   #5
86_Notch's Avatar
1986 lx notch
9.98 @ 135
not emissions, it won't pass because of the noise, mine failed because the db was too high
Old February 13th, 2008, 10:45 AM   #6
trueblue01's Avatar
1989 Mustang LX
10.98@126.7 NA
trueblue01 is on a distinguished road
I'd use an "X" pipe configuration instead, better flow and scavenging. I used Summit's 3" universal kit. It's fairly adjustable and as long as you have moderate fabricating skills it's pretty easy. It fit my Fox platform very nicely using Hooker Super Comp long tube headers. I did modify my crossmember slightly to facilitate easier installation.
Never fast enough.
Old February 13th, 2008, 01:26 PM   #7
1990 Mustang GT
i dont know if i cud pull that off with the whole fabication thing......i wud much rather find an h pipe that was just bolt on and 3 inch and for longtubes.....and of course i will have to get headers with 3in collectors
Old February 13th, 2008, 02:15 PM   #8
ryans88gt's Avatar
MAC PC3393 MAC 1979-93 Mustang 5.0 3'' Off Road Pro Chamber to MAC Long Tubes- 5spd - PC3393 MAC
Personally, I'd look for a 3-bolt collector or slip on collector setup.
The 3-bolt collector is worth 10-15 hp over the restrictive ball-socket OEM design. Sure it seals better, but the ball part goes from a 3" opening to a 2.75" opening or smaller.
Old February 13th, 2008, 02:26 PM   #9
1990 Mustang GT
why is that so expenive.....and i wud think more companies would have 3in exhaust components than thistletle
Old February 13th, 2008, 10:23 PM   #10
blacksabith77 is on a distinguished road
thats going to be loud
Old February 13th, 2008, 10:43 PM   #11
1990 Mustang GT
i cant believe its this hard to get the exact exhaust system.....is it so much to ask for full length headers with 3 in collectors slip fit....with a 3 in h pipe or i would even settle for an x pipe...
Threads Similar to: 3 inch exhaust setup
3 Inch Exhaust Xantho99 99-04 26 November 27th, 2007 08:58 AM
Exhaust Setup ZoomZoomMFer 96-98 19 November 22nd, 2007 04:39 PM
Exhaust Setup For my V8?? tBuck345 General Tech 25 June 28th, 2007 10:19 PM
What's The Best Exhaust Setup? MustangMo V6 Mustangs 23 April 21st, 2007 03:20 PM
Exhaust Setup ?s Avaric3 V6 Mustangs 18 April 4th, 2007 10:41 PM
