Discussing 1990 ford mustang in the 5.0 Mustangs Forum. So I can pick up a 90 gt for cheap, but the guy says that ...
Old February 16th, 2008, 11:01 PM   #1
1990 ford mustang
So I can pick up a 90 gt for cheap, but the guy says that there is no transmission fluid because it all leaked out. And he said that its not driveable, of course. But my question is that is it repairable or do I need another trans??? Also its an auto. ANd how much am I looking at spending for a swap? Thanks guys
Old February 16th, 2008, 11:03 PM   #2
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
you can find a new trans fairly cheap.. but if it just leaked out my questions would be... how? where? did you drive it after and if so for how long?
Old February 16th, 2008, 11:22 PM   #3
invisa stang's Avatar
1992 mustang lx notch
depends on where it leaked from wheither its fixable or not
and a swap kit isnt that much (i dont know a exact price but im pretty sure its not much)
www.myspace.com/lifeisasboringasdeath
rides
1987 ford F-350 XLT Lariat 7.3L idi diesel
projects
1979 ford F-350 custom (soon to get 7.3Lidi diesel)
Old February 17th, 2008, 02:35 AM   #4
Well the guy said that it needs a new gasket but I have not driven it becuase he said that it is not driveable as is. He said that it was leaking and ran out of fluid and it stopped going into gear. My I thought that if you cant shift into gear than the tranny is fubar. How much would it be to get one installed?
Old February 17th, 2008, 02:37 AM   #5
depends on where the gastket thats leaking is
rides
projects
Old February 17th, 2008, 02:42 AM   #6
Well all he said is that it needed a gasket that costs like 15-25 bucks. And he said that it slips as is because there is no fluid. BUt if I refilled with fluid and replaced the gasket do you think that would fix the problem?
Old February 17th, 2008, 02:50 AM   #7
1992 mustang LX
7.21 1/8 mi
heres what you do, put 3 qts of atf and 1 quart of lucas and drive that bitch. yeeha !!
c'mon sunshine !!
http://i29.tinypic.com/2eq9zy9.jpg
Old February 17th, 2008, 02:50 AM   #8
no that wont replace a slip in the tranny
rides
projects
Old February 17th, 2008, 02:52 AM   #9
So more then likely it will need a rebuild?
Old February 17th, 2008, 11:31 AM   #10
baine21225's Avatar
and what if the car has some other issues? is he going to pay for those when you get the tranny fixed?
Old February 17th, 2008, 01:31 PM   #11
1992 mustang LX
7.21 1/8 mi
the most common reason a tranny slips is because its low on fluid, he said it had a leak, so fill it, drive it, then check to see where its leaking.
c'mon sunshine !!
Old February 17th, 2008, 01:36 PM   #12
e3sean's Avatar
1988 lx 5.7
11.6@109
is it a auto or 5 speed there is no gasket in a 5 speed that costs 15-25 dollars there are no gaskets on a 5 speed there are only 2 seals that are only 2-3 dollars each but if its a 5 speed it would go into gear with no fluid in it .. auto is a differnt story....
the only thing u will be burning by going with a 347 insted of a 331 is the guy driving the 331
MILITARY CREW
USAF LUKE AFB AZ,
E-5 SELECT 7995
AMMO I.Y.A.A.Y.A.S
Old February 17th, 2008, 02:32 PM   #13
yeah its for sure an auto, My question is now how much are used transmissions because I am not finding anything?
Old February 17th, 2008, 02:53 PM   #14
Iwannagofast's Avatar
1990 Mustang GT
9.39@76.09----1/8th mile
if its a slow leak which it probly is fill it with some atf and that lucas stuff that was mentions......its good stuff......and then you could probly test drive it at least and see where your at......im guess its the gasket on the pan
stang=40's dumped,pro 5.0 short throw, king cobra clutch, adj. clutch cable and firewall adjuster...pretty much stock
2001 tacoma=magnaflow, K&N cai, tb spacer, 2.5" susp. lift, 32x11.50s, electric fan, few dress up items
Old February 18th, 2008, 12:22 AM   #15
1992 Mustang GT
Well you can find and AOD transmission for 300.00 or Higher. I wouldn't go no higer then 500.00 on and AOD. T5 you'll be paying a crap load more cause you need the pedal assembly, the clutch plate the bell housing, the shifter and the T5. you sink probably 1,500.00 alone if your lucky on a Manuel. AOD's drop fix slap in a shift kit. slap it back in put a better stall converter in it I'd say up to 1,000.00 or cheaper. Look on craigslist classifieds: jobs, housing, personals, for sale, services, community, events, forums Its the best place to find used autoparts for Stangs. I find stuff all the time in my area.
Whats that noise? Did I just dump the Trans!!!
Old February 18th, 2008, 01:11 AM   #16
So if i got a shift kit that would solve the problem?
Old February 18th, 2008, 01:15 AM   #17
1990 Mustang GT
a shift kit would just make it shift faster and harder......he was just naming some performance mods to do to it while you had it out of the car
Threads Similar to: 1990 ford mustang
1990 Mustang GTR $69k TurboLX The Clubhouse 25 October 21st, 2007 12:22 AM
1990 mustang 5mustang0 For Sale 14 August 24th, 2007 01:15 PM
1990 Ford Ranger XLT fuel pump problem ScyraxxX All Other Vehicles 22 August 9th, 2007 03:15 PM
1990 Ford Ranger Xlt Starting problems. Thuemen All Other Vehicles 3 April 22nd, 2007 02:44 AM
My 1990 Ford Ranger Transmission JThug69420 All Other Vehicles 1 July 14th, 2006 04:02 PM
