Discussing Smog Pump Delete? in the 5.0 Mustangs Forum. On my 1995 i want to get rid of the smog pump and all the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Smog Pump Delete?thanks
1995 GT 5-Speed: 14.4 @ 96.1mph |
i am also planning on putting aftermarket heads/intake on this winter...any changes for these?
Just went through what you are doing with my 83 convertible and 93 5.0 motor. I bought the FRPP thread in plugs for the heads, don't waste your money on these, the hole has to be tapped and can't be done with the engine in the car.
Older heads use a frost plug type blocker, I just cut the tubes off the manifold that goes into the back of the heads, then flipped these around and bolted them over the hole in the head. Used a some high temp rtv silicone just as a precaution for leaks. There was no gasket originally and there wasn't any leakage. If you delete the pump why not just remove the hardware and get rid of it, and run a shorter belt? There is a posing on this forum somewhere for the belt installations depending on your accessories. |
remove the smog pump and all the piping that goes with it. you can weld the bung on the intake manifold shut and also where it goes into your midpipe. just put a plastic cap (plug) on the 2 vacuum lines that will come off when you remove the pump. get a smog pump delete pulley and install it on the original smog pump bracket. dont go for the shorter belt thing. it will cause you problems down the road. the stock belt will fit with the delete pulley
thanks
I read somewhere that smog pumps or air pumps help heating up the air or the emissions in order to allow it flow easily through the catalytic converters.. I think you shouldn't eliminate/delete the smog pump unless you wanna remove the cats - use off road H-pipes..
not to be sarcastic but read my sig [o/r h-pipe]
whoa
![]() I had those, but because of the cops & emissions law.. had to purchase Catco hi-flow cats and put them on. Some think that cats may hurt performance a bit, but your engine makes a better use of the H-pipe when the cats are there. |
go to your local parts store and buy belt number K060770 and then you dont have to buy the pulley to delete the smog pump
I snatched the cats and smog pump put bolts in the back of my heads and put on headers so no need to plug holes in exhaust. Heres the belt routing if u decide just to snatch the pump and get a shorter belt. Mine has been tearin up road for almost 6 months with no problems with the shorter belt.
Yeah, its ugly, but hot damn its fast! Got 2 camaro SS's and 1 LT1 vette under mah belt in it! |
hey thats good it helps me out to. I am doing the samething myself.
#12 | |
The Cable Guy...
SLOW
My freind deleted his smog pump on his 5.0 and he is very happy with it...He also deleted the A/C at the same time... |
I also pulled out the A.C.
I pulled the smog and power steering. Just move your belt tensioner from on top of the belt pressing down to under the belt lifting up. Lift up on the tensioner until you have the propper tension on the belt and tighten down the nut that secures the tensioner. There won't be a spring pressure tightening the belt this way but this is no problem. My friends and I have been running ours like this for over 10 years without any problems. Cars used to put tension on the drive belt like this pulling the alternator until the belt tension was right and tightening it down for 70+ years before they ever made a tensioner. In over 15 years messing with mustangs I have not heard of a single problem running it this way.
Hey, I need the AC relay connection and relay on the passager side fender and a half a foot of wire. Also the connector for the dryer too!
about this short belt stuff....i have a 1995 5.0 and i have a tensioner pulley and an idler pulley, not sure if those are the right lengths for me
Hey I just tried 6 different belt sizes before I got it right and mine was a 74 inch belt size. I got a 93 lx.
i never use my a/c, so do i have to have the belt around the a/c pulley? Do i have to get a delete for it, or can i just get a belt that doesnt go around it? If i deleted the a/c, does that bring more horse power or something? I just never use it and would like to free up some more power.
Suck on it Trebek. Suck it long, suck it hard.
Yes there is an A.C. delete get one and put it on. I got mine from tommie vaughn ford in Houston. The one I have moves the power steering pump where the A.C. compressor was, and it was so easy to do.
#20 | |
BBK CAI and Shorty Headers, Cobra Upper/Lower Intake, Walbro 110, 24# Injectors, larger throttle body, maf, Drilled and slotted front rotors, King Cobra clutch, Cobra wheels w/ sumitomo tires, flowmasters |
Threads Similar to: Smog Pump Delete?
| SMog pump delete kit | javier351lx | 5.0 Mustangs | 9 | August 20th, 2007 02:24 PM |
| smog pump delete | bigwhiskey | 5.0 Mustangs | 4 | June 30th, 2007 11:02 PM |
| How To Delete Smog Pump On 95 GT | the95..5-0 | 5.0 Mustangs | 2 | September 13th, 2006 12:43 AM |
| Smog Pump Delete | mdvaldosta | 5.0 Mustangs | 2 | September 11th, 2006 11:13 AM |
| Smog Pump Delete? | 00SoSlow | V6 Mustangs | 18 | August 16th, 2006 12:04 AM |
