Freaking IDLE - Page 2
Old February 26th, 2008, 10:26 PM   #21
King of Clubhouse
Till's Avatar
I know all about zombies!
I killed a zombie in .3 seconds
Till is a splendid one to beholdTill is a splendid one to beholdTill is a splendid one to beholdTill is a splendid one to beholdTill is a splendid one to beholdTill is a splendid one to beholdTill is a splendid one to behold
Send a message via AIM to Till
Originally Posted by tehdwarvenn View Post
thats ur TPS = throttle positioning sensor. BTW the IAB can be called anything with the combination of the words
Air .
Idle.
Control.
Bypass.
=) IAB, IAC, AIC, AIB any of those work. does the same thing. little solenoid that lets air in your intake. lol.
lol ok thanks for the info man, could the TPS have anything to do with it?
Originally Posted by quickndslick2 View Post
^^go burn in a fire
Dumbass Club Founder
MM + Cleavage member #23
Old February 26th, 2008, 10:33 PM   #22
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
have you checked for codes yet??????
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old February 26th, 2008, 10:34 PM   #23
1993 mustang lx convertib
saldoggs is on a distinguished road
you know you have to set the TPS (the little black thing on top) to .95 to 1.0 volts to make the car run right if you put it on with out seting it the car will race like that too
Old February 26th, 2008, 10:36 PM   #24
King of Clubhouse
Till's Avatar
No man I had no idea can you explain that to me, no one ever told me that and I didnt see it any where I was told throw on the TB and go,
and no I didnt check the codes I dont know how
^^go burn in a fire
Old February 26th, 2008, 10:46 PM   #25
kevnsue is on a distinguished road
i am a ford mechanic and I will tell you right now it is your computer. Change it and all your problems will be gone! well with that anyways. HAHA No really change your computer.
Old February 26th, 2008, 10:53 PM   #26
King of Clubhouse
Till's Avatar
ok how much does that cost and where is it thanks alot man
^^go burn in a fire
Old February 26th, 2008, 11:59 PM   #27
02 Mustang GT
Cant wait to find out
Black Five 0h is on a distinguished road
i dont think you should change your computer yet it is too early to tell check everything else first then try your computer..you will see more problems with a failing computer
02 Mustang GT
"We build it up, run it hard, we know whats breaking and we enjoy it breaking, we dump money into it, we re-build it stronger, run it harder in anticipation of it breaking again. We are sick individuals."
Old February 27th, 2008, 12:26 AM   #28
ryans88gt's Avatar
Some ford technician...the computer can't make the car idle at 3000. Physically, the engine needs air to get to 3000 rpms. You have air getting to the engine somehow. This is either
1) the TB plate is adusted poorly
2) the IAC is stuck wide open
3) you have a vacuum leak (this could be through your PCV or EGR system)
To troubleshoot, take the IAC off and block the hole with your hand or something else to seal the hole. If you idle is still 3000, it is not the IAC. Put the IAC back on, and block off the TB. If still at 3000, you have a vacuum leak.
Old February 27th, 2008, 10:20 AM   #29
King of Clubhouse
Till's Avatar
Ok Thanks man your so smart lol
and when you mean block off the TB how do I do that im kind of lost there
^^go burn in a fire
Old February 27th, 2008, 12:42 PM   #30
He means get your wife to go out there and put her hand against your throttle body and see if it dies! He is so smart!
Threads Similar to: Freaking IDLE
so freaking mad rigth now!!!!! El_Cangri The Clubhouse 65 September 24th, 2007 07:42 PM
EEEC-IV Freaking Out? armadillon 5.0 Mustangs 5 September 24th, 2007 01:23 PM
ok whats the freaking difference???? droppedbass87 96-98 3 September 23rd, 2007 09:10 PM
bout freaking time! 232stang The Clubhouse 12 June 8th, 2007 12:17 AM
freaking a 232stang The Clubhouse 4 June 6th, 2007 11:45 PM
