Bogging Down While Accelerating
Old October 1st, 2006, 01:43 AM   #1
dcraig8 is on a distinguished road
hey guys, im having a problem with my 94 gt. when i accelerate it starts missing or bogging down real bad. my a/f ratio gauge starts spazzin out and im losing power. once i get up to speed, it runs fine, until i go to accelerate again. i did notice that my left o2 sensor is chaffing against my transmission cover shield and wandering if it chaffed through the wiring, but this all started happening after a heavy downpour and while driving home, i went through some pretty deep water. any ideas?
Old October 1st, 2006, 02:17 AM   #2
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Sounds like a coil or distributor issue...
Facebook
Google+
Old October 1st, 2006, 12:06 PM   #3
Screemin3o2 is on a distinguished road
Send a message via AIM to Screemin3o2
if you dont have the stock hood, water could be getting to the coil or distributor somehow bu tthat wouldn't explain why its only under acceleration. Its possible that it is the o2 sensor. I would check the TPS and MAF also.
95 Mustang GT
Slow Bolt On Car
www.steelcitystangs.com
Old October 1st, 2006, 03:04 PM   #4
mine had the same problem. i changed the distributor cap and rotor, fuel filter, and i got an oil change and it is back to normal. the oil change is what brought the power back and the bogging stopped after that. hope that helps with you but it sounds like a different problem.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old October 1st, 2006, 03:06 PM   #5
raceruler03's Avatar
2000 mustang gt
raceruler03 is on a distinguished road
Send a message via AIM to raceruler03
it could even be as simple as a spark plug starting to file out or an injector going bad
Old October 1st, 2006, 03:23 PM   #6
88BlueGT is on a distinguished road
Send a message via AIM to 88BlueGT
Make sure that all of your ignition wires are tight and like suggested above make sure that all of your spark plugs are snug...
93 GT - Full Exhaust, 3.90's, Front Tubular Suspension, etc.
88 GT "Big Blue" - Body work & primer!
Threads Similar to: Bogging Down While Accelerating
Car pulsates when accelerating between 2k and 3k rpm k3vin 96-98 3 October 27th, 2007 11:30 AM
Why does my car keep accelerating? krisp1108 V6 Mustangs 8 September 30th, 2007 01:12 AM
accelerating problem smoke-em 4V / SVT 6 May 22nd, 2007 01:02 PM
My Car Is Still Bogging Out 98 gt 96-98 4 November 15th, 2006 02:01 PM
Car Is Bogging Out 98 gt 96-98 5 November 12th, 2006 09:07 AM
