Discussing Heat question in the 5.0 Mustangs Forum. Last year I couldn't get any heat out my 89 LX. With in the ...
Old October 19th, 2005, 06:53 AM   #1
Heat question
Last year I couldn't get any heat out my 89 LX. With in the last year I've changed the water pump and the thermostat but that didn't seem to help. In the last couple of months I've gotten a small coolant leak, not sure from where, but I can smell it and it pools on top of the timimg cover. Well since the leak started I've started getting heat now. Any ideas as to what is going on?
Thanks
Jeff
Old October 19th, 2005, 07:09 AM   #2
Modded Autos Site Mod
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
maybe heater core? if you get some smoke in the car and you still smell it, it is probably the heater core. swapping it out requires removal of the entire dash and is about 3 hours total work or a couple hundred bucks in labor at a shop. if it is the core, just remove the hose for it (disable it) until you can fix it.
ModdedAutos
1999 Mustang V6
Old October 19th, 2005, 01:44 PM   #3
It's not the heater core, coolant is pooling on the motor from somewhere. The fact that I've got heat now is a good thing, I can still control it. I was just curious as to why it took a leak for the heat to start working.
Old October 19th, 2005, 06:57 PM   #4
14.79 @ 92.15
i havent a clue. maybe someone with more 5.0 knowledge could chime in
ModdedAutos
1999 Mustang V6
Old October 19th, 2005, 07:18 PM   #5
maybe u had some air in the lines i drill a small holl in my termostad to let any air out of the system i read these in a book the i got call (5.0 performance hanbook) lots of cool stuf in there
http://www.moddedmustangs.com/hosted...rd-mustang.jpg
SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$%
Old October 19th, 2005, 08:52 PM   #6
Most likely you installed the waterpump or thermostat gasket wrong, and it didnt seal properly.
http://i2.photobucket.com/albums/y21...T0372black.jpg
Everything + Nitrous
Old October 21st, 2005, 11:39 PM   #7
Re: Heat question
Thanks
Jeff
Anyone ever replace the lower intake gasket to the heads?
The front coolant passages on most felpro gaskets have to be cut out to match the ports and if you don't do that the flow is restricted by the gasket making the heat issue you discribe and eventually the water over the restrictive gasket bends it and tears it and causes a leak between the lower intake and the head that puddles on the timeing cover. Uasually the drivers side is the 1st to go.
Threads Similar to: Heat question
keep intake heat down? blakeasaurusrex Modular Mustangs 4 September 7th, 2007 12:24 AM
Starter Question/ Problem (Heat Soak) xjer88 5.0 Mustangs 13 March 7th, 2007 10:55 PM
no heat hmotes 5.0 Mustangs 8 January 15th, 2007 04:24 PM
Heat / Air terribleonexx88 5.0 Mustangs 3 October 19th, 2006 12:09 AM
Please help with the heat tdurbin 5.0 Mustangs 12 May 19th, 2006 11:15 AM
