5 Lug Conversion?
Old March 1st, 2008, 01:59 AM   #1
burnout5.0's Avatar
2004 Mustang SVT Cobra
448whp/475wtq
burnout5.0 is on a distinguished road
5 Lug Conversion?
Ok my my friend just picked up an '86 GT and hes looking for the 5 lug conversion kit but can only find ones for '87-'93? will that one work or is a completely different one the '86? and if so where can i find it?
Old March 2nd, 2008, 10:41 AM   #2
ryans88gt's Avatar
If he has an 8.8 in the back they are the same.
Old March 2nd, 2008, 02:00 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You will need 83-92 4 cylinder Ranger rotors in the front and 83-92 4 cylinder/3.0 V6 Ranger driver side axles and drums or 86-97 Aerostar passenger side axles and drums. You could convert the front suspension to 87-93 style also and then use 85-91 Lincoln Mark VII front rotors. The rear is the same whether it is a 7.5 or an 8.8, they use the same axles.
Old March 2nd, 2008, 02:48 PM   #4
1987 Mustang GT
stone84 is on a distinguished road
I was just going to make a topic asking about the conversion, but since one is all ready up I'll just throw my question on here.
Is it really worth going from 4 to 5 lug? Anything really special about converting or just a few more wheels to pick from?
Old March 2nd, 2008, 05:38 PM   #5
merk is on a distinguished road
brake selections improves greatly going to five lug
Old March 2nd, 2008, 05:41 PM   #6
built351w's Avatar
1979 mustang 5.0
hopefully 11's when complete
built351w is on a distinguished road
brake selection and wheel choice. Personally unless you are building a road race car, i don't see it worth the money....... You can get really good 4 lug rotors...
1979 hatchback:
-351w w/ 10.5:1
-Tremec TKO
Old March 2nd, 2008, 06:50 PM   #7
1987 Mustang GT
Thanks guys, that's what I figured. burnout5.0, sorry for jacking your thread.
Old March 2nd, 2008, 10:35 PM   #8
jrh_1980's Avatar
89 Mustang LX
7.90@90mph 8th
jrh_1980 is on a distinguished road
another cheap way to do the 5 lug conversion is to get the front hubs off of an 80 something lincoln markVII and two driver side axles from a couple explorers. remember you have to use the posi unit too because they are 31 spline axles. all can be picked up at the local junkyard for under $100.
Old March 2nd, 2008, 10:53 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Wheel choice is about it but pretty much every aftermarket wheel company makes wheels in 4 lug for Mustangs now anyway. Brake selection isn't really a benefit unless you are getting larger rotors and if that is the case you won't be doing a Ranger or Lincoln rotor swap anyway. The only thing that changes between a stock 87-93 4 lug rotor and a Lincoln rotor is the number of wheel studs. Everything else is the same.
Threads Similar to: 5 Lug Conversion?
'05 Conversion Kit for '99-'04 OhhShorty 99-04 31 September 28th, 2010 05:44 PM
5 lug conversion BWAL 5.0 Mustangs 15 September 16th, 2007 05:09 PM
3.8L to 5.0L conversion sisch General Tech 1 June 25th, 2007 01:29 PM
2.3L to 5.0L conversion stan_doe 5.0 Mustangs 6 January 23rd, 2007 01:39 AM
