battery in trunk, crappy start
i put the battery in the trunk and ran 1 power wire up to the sil, i self tapped the ground in the trunk,, just to the sheet metal, now when i start it, it takes forever, and its not charging the battery now, im confused.
91 LX 5.0
11.87
I have mine in the back and have no problems.
I grounded to the quad shock bolt hole
ur ground is probably not efficient enought... make sure it is grounded to a bare piece of un painted metal. The frame is best and it shouldnt be a problem to run it down there... there should be a rubber grommet under the spare tire that will let you run the ground right under the car, without having to drill a hole
i have my battery in the trunk, i'll try and get some pics today, but yea, a sheet metal ground i dont think is going to cut it
i fought a ground problem and ended up running it all the way back up to the freakin' block!
[SIGPIC][/SIGPIC] [SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE] |
Put the battery back where is belongs
![]() I moved my battery to the passenger side rather than relocate it to the trunk for this very reason (I had to move the battery to fit my procharger).
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
yea thats always an option too... lol but i know thats not what u wanna do, obviously. i just kept mine under the hood as i realized that i didnt want to create any problems that i dont have to deal with now
1986 lx notch
9.98 @ 135
don't forget to run a ground strap from the engine block to the frame
#9 | |
2002 Gt
Not Slow
![]() iTrader: 1 reviews
+1 |
2008 Hammock Rodeo Champ
another good grounding point in any car is the seats. take one of the bolts loose from the frame and ground it there. even in a fiberglass vette. best place for it IMO.
i have no mustang. so don't listen to anything i say. |
+1 ive heard many people relocating their battery successfully when they attach the ground to the seat bolt
To small of power cables or bad connections.
what gauge wire did you use.
85 svo. work in progress
1989 LX Coupe
Did you clean the grind/clean the paint off from the sheetmetal area that you grounded to?
Threads Similar to: battery in trunk, crappy start
| crappy day...got fired :( | tlr96 | The Clubhouse | 34 | February 20th, 2008 06:55 PM |
| Putting battery in the trunk? | saxmanJJ | 99-04 | 17 | February 13th, 2008 11:40 AM |
| Crappy day | travis_afx | The Clubhouse | 21 | October 8th, 2007 01:13 PM |
| battery in trunk | 5LBennett | 5.0 Mustangs | 3 | July 1st, 2007 10:01 PM |
| crappy conditions but here's the new times | SWEET2KSTANG | 99-04 | 7 | April 2nd, 2007 05:53 PM |
