Discussing Trac-Lok rebuild how to. in the 5.0 Mustangs Forum. i guess i came back at the right time seens how i plan on doing ...
Old March 13th, 2008, 01:17 PM   #41
i guess i came back at the right time seens how i plan on doing this soon wheres the best place to buy a rebuild kit i know mustang unlimited has them just wondering of other places
Shawn
svergilia90@yahoo.com
Old March 13th, 2008, 01:27 PM   #42
ryans88gt's Avatar
Laurel mountain is the cheapest place that I know of that sells the Ford kit.
89 LX 515 hp 497 ftlbs 11.3 @ 125 mph
88 GT 11.4 @ 118
Old March 16th, 2008, 03:37 PM   #43
ryans88gt's Avatar
The last step, I bought this MAC diff cover for $100 on ebay and it was ceramic coated. It allows for about 1/2 quart more fluid and has a drain and fill plug, but the best features are the bearing cap supports. Ultra black rtv around the center section. Put the cover on and torque the 10 bolts down. Tighten the bear supports to 5 ftlbs and the jam nuts to 15 ftlbs. Let the RTV set up for an hour and then fill with 2 1/2 quarts of gear oil (synthetic is worth the money here since most people change the rear fluid very infrequently). Don't forget the friction modifier and the full plug.
88 GT 11.4 @ 118
Old March 31st, 2008, 11:09 PM   #44
1988 Mustang GT
Good post thanks
Old April 4th, 2008, 02:49 AM   #45
Hunt_chevs's Avatar
88 Gt
Not Slow
How long did this take you?.. for the entire rebuid
Old April 4th, 2008, 01:43 PM   #46
ryans88gt's Avatar
about 2-3 hours including all the pics.
88 GT 11.4 @ 118
Old April 21st, 2008, 02:01 AM   #47
SALIV8's Avatar
I lost my posi at the track today , trying to decide on rebuild kit, or just go with an auburn unit or equivalent. Great thread and itll help me do it myself. thanks
Old April 21st, 2008, 02:03 AM   #48
v606er's Avatar
69
Originally Posted by HMUSN View Post
nice write up man
thats pretty goood
steeda UDP, steeda CAI, xcal3 w/ 93oct tune, 3.73's, tlok
magnaflow exhaust is in, waiting until late December or early January for the install.
Old April 21st, 2008, 08:42 AM   #49
ujslost's Avatar
rebuild it dude!
Costs alot less than a locker will.
Old April 21st, 2008, 01:14 PM   #50
ryans88gt's Avatar
I've had about 100-200 passes on a 4 clutch rebuild with no signs of one wheel peel yet.
88 GT 11.4 @ 118
Old April 21st, 2008, 09:53 PM   #51
SALIV8's Avatar
i decieded on the carbon discs rebuild kit. Thanks for that tip too. The clutches in the 8.8 lasted one pass for me on drag radials with a decent 1.8 60' time. I hope these last longer!! I should get the 60 down to 1.6 if these hold up. Thanks again Mr. Ryans88gt
Old April 21st, 2008, 11:21 PM   #52
ryans88gt's Avatar
it's actually dr. but your welcome. I've been running 1.5 60 foot times with the standard rebuild, hopefully you'll have better luck in the future.
88 GT 11.4 @ 118
Old April 21st, 2008, 11:24 PM   #53
ujslost's Avatar
was this a fresh rebuild that you burnt up on the first few passes?
Old April 21st, 2008, 11:36 PM   #54
SALIV8's Avatar
i dont know how old it was, but Im sure it wasnt fresh. I bought this car used and have had to tweak quite a few things so far, so Im assuming its at least a year old. if a fresh set can hold 1.5 times for DR. ryans 88 gt, the carbons will be overkill for me but ive had to drop the rear girdle 3 times now in 3 weeks and im getting sick of doing it. i hope this will be the last time this season at least.
Old April 21st, 2008, 11:41 PM   #55
ujslost's Avatar
oh ok.
well just soak the clutches in friction modifyer before ya install them and then break them in before ya go beating on it.
Old April 21st, 2008, 11:50 PM   #56
ryans88gt's Avatar
The carbons hold up pretty well for 500 hp cobras so you should be in good shape. Do make sure you soak the clutch discs before installation. I usually just soak them in gear oil though.
88 GT 11.4 @ 118
Old April 22nd, 2008, 04:54 PM   #57
SALIV8's Avatar
ok, Ill soak 'em
Old April 22nd, 2008, 04:55 PM   #58
SALIV8's Avatar
whats break in? 50 miles? couple launches?
Old April 23rd, 2008, 03:11 PM   #59
ryans88gt's Avatar
Do a few donuts in both directions. If you don't hear any pops and bangs you are good to go. If you do here some popping, drive the car around a little bit until it goes away (took me about 150 miles after this last rebuild because I shimmed it a little too tight).
88 GT 11.4 @ 118
Old April 23rd, 2008, 10:41 PM   #60
SALIV8's Avatar
thanks
Threads Similar to: Trac-Lok rebuild how to.
trac off blazor V6 Mustangs 6 January 13th, 2008 08:36 PM
trac off blazor Suspension 1 January 13th, 2008 04:39 AM
Trac-Lok Kennhyy3 V6 Mustangs 7 April 20th, 2007 10:09 PM
Trac lok postie V6 Mustangs 13 December 29th, 2006 01:24 AM
Trac Off stanged out V6 Mustangs 22 November 21st, 2006 03:31 PM
