| LinkBack (101) | Thread Tools |
#81
hopefully i dont need this sticky as the rear end was rebuilt with frpp 4.10s right befo i baught car...but it feels like its strugglin already to keep both spinnin...maybe i need carbons...but im only runnin a stock 93 5.0 H.O motor with bbk equal length shorties and 70 mm edelbrock TB and EGR spacer...and a aod with stage 1 shift kit...and the torqe bars...any suggestions would be much appreciated...
#82 |
2.0t MKV volkswagens are still faster
#83 |
1992 5.0 Mustang GT 'Vert
Do the pics no longer work?
#84 |
Stack thickness
Ryan,
GREAT HOW TO.. took half an hour to completely tear it down, although I couldn't open the photos. The complete used stacks measured .641 and .643 The new stack with the added, used, outside and flipped clutch measures .631 with no shim. Thinnest shim in the rebuild kit is .030, which gives me .660 total thickness. Is this too tight and if so where can I get .020 shims? BTW the old clutches were worn VERY thin so .660 may or may not be right on. Your thoughts please. Thanks Bill Last edited by BillBuckley; February 11th, 2010 at 11:21 AM. Reason: Can't spell!! |
#85 |
Try it and see if it fits. If you can't get the cross pin in there easily, then it is too tight. The kits I have used in the past came with shims as small as 0.010...
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#86 |
PS, sorry about the pics, don't know why they don't load anymore. I still have them, maybe I'll repost them if I get bored.
#87 |
1995 Mustang GT
IDK Fast
nice how to. question will a 2000 gt 8.8 rearend fit in a 95 gt's spot or do i have to get a 94-95 axle
#88 |
1995 Mustang GT
IDK Fast
figured it out thanx everyone
#89 |
This a nice write up, but I guess over time the pics faded away LOL. any way you could repost them?
#90 |
PLEASE REPOST te pics!! PLEASE! I have to do this this weekend and I sure would love the pics to go with your write up as Im working on it....
![]() 02GT - Blown motor 86LX 3.8TBI auto replacement daily driver How to retrofit HID's |
#91 |
I reuploaded the pictures
After cover removal ![]() Remove center pin bolt ![]() Remove Center pin ![]() Push in axles, Remove C-clips ![]() Pull out axles ![]() Remove S spring ![]() Rotate using one axle to remove planetary gears ![]() Remove clutch packs and side gears
#92 |
Clutch Packs
![]() Reinstall repacked clutches and side gears together with shims ![]() Use center pin to line up planetary gears ![]() Rotate planetaries into place using one axle ![]() ![]() Use worm gears to clamp S-spring ![]() Reinstall S-spring ![]() Remove worm gears using a combo of vice grips and small screwdriver ![]() ![]() Axles back in ![]() C-clips back on and center pin back in ![]() Tighten center pin bolt ![]() Add a nice cover
#93 |
1995 Mustang GT
IDK Fast
man lovin the writeup more and more how hard is it to remove the gears???? the one that will be the b***h is the little one right???
1995 mustang GT- mods out the a** 1995 mustang- Parts, Parts 1998 mustang V6- was DD, now tranny is out
#94 |
cool
#95 |
To remove the planetary gears, put the car in gear with the S-spring and center pin removed. Push one axle back into the trac-lok unit and rotate the axle which will rotate the gears out of the carrier.
#96 |
Look Ma! My First Post!
Don't mean to ask question that night have already been answered, but can you rebuild these without taking out diff in about all mustangs.? I have 2002 Saleen S281, need to rebuild.
#97 |
Very Very good writeup, I was looking for a how-to, since my posi needs a rebuild. Thanks very much for your help! BTW, awesome pictures as well!
#98 |
Stock 1983 Mustang GL 5.0
13.78@96.26
Great write up! I am doing this very thing this week, I already did it this weekend but used the existing used clutch pack, it was unsuccessful as they were just too worn. So I have new clutch packs on the way.
I just wanted your thoughts on eliminating the S spring. My Drag racing buddy used to work for a performance Ford magazine. And has done this build for years. So, the idea is if the car will never be driven on ice or used on a surface that would require preload on the clutch packs, the S spring is not necessary. As long as it is tight without the S spring, then for Drag use or performance use, there is no need to preload the packs. The engine torque will over-ride the S spring preload. If the pin is snug against the axles then only a miniscule amount of torque will force the clutches to lock. I have it apart again right now, and am considering not preloading with the S spring. The main idea is there is unnecessary preload under no torque conditions (such as ice) and actually causes the clutch packs to wear faster under normal driving. What are your thoughts on this? Thanks
#99 |
I would leave the S-spring in there. As the clutches wear, you will need the S-spring to keep tension on the clutches because even if it is tight when you put it together, 1000 miles from then, there will be some space that needs to be taken up.
#100 |
13.78@96.26
Sounds reasonable. Ill put the dreaded spring back in.
Again, excellent write up. The most difficult things about this rebuild are jacking up the car and taking the wheels off, oh and the scraping. I notice this write up was written quite a while ago, are you still using this rebuild? |
Threads Similar to: Trac-Lok rebuild how to.
| trac off | blazor | V6 Mustangs | 6 | January 13th, 2008 08:36 PM |
| trac off | blazor | General Tech | 1 | January 13th, 2008 04:39 AM |
| Trac-Lok | Kennhyy3 | V6 Mustangs | 7 | April 20th, 2007 10:09 PM |
| Trac lok | postie | V6 Mustangs | 13 | December 29th, 2006 01:24 AM |
| Trac Off | stanged out | V6 Mustangs | 22 | November 21st, 2006 03:31 PM |
