Trac-Lok rebuild how to. - Page 6
LinkBack (101) Thread Tools
Old July 11th, 2010, 10:36 PM   #101
Cudascious's Avatar
Stock 1983 Mustang GL 5.0
13.78@96.26
Cudascious is on a distinguished road
Well I finished that last week, I am glad you confirmed the clutch/steel order. Now its a super trac lok! Amazing....
Old July 28th, 2010, 01:50 AM   #102
SCREAMPUFF87GT is on a distinguished road
I just did the same job and you are spot on my man!! nice follow through.
Old August 13th, 2010, 03:56 PM   #103
ryans88gt's Avatar
Glad everyone is still enjoying this write up. I just picked up an SN-95 and it needs the trac-lok rebuild, so looks like I get to swim in some gear oil again.
Old September 24th, 2010, 12:19 PM   #104
91cobra5.0's Avatar
94 GT
great write up, i am going to be doing this soon and am going with the ford racing carbon clutches, would adding the f150 s spring be too much with the carbon clutches?
Old September 28th, 2010, 08:00 AM   #105
5.0chad is on a distinguished road
After i got the s spring back in i noticed that one of the spider gears can move up and down in the diff. about 1/16 of an inch. is this normal or is there something wrong. i dont have the center pin in yet because one of the orings on the axle where the c clip goes ripped. will any o ring work or is it a special one.
Old September 28th, 2010, 10:02 AM   #106
ryans88gt's Avatar
You don't really need that o-ring. It sounds like you may need more shims behind your clutch pack if you have excess play in the planetary gears (that means your spider gears are too far apart).
Old September 28th, 2010, 12:50 PM   #107
The clutch pack were tight that i could barely get the spider gears to clear to go back where they are suppose to. does the s spring touch the spider gears once is is back in an y would only one spider gear move and not the other? it barely moves when it is back up inside the traction lok housing
Old September 28th, 2010, 05:03 PM   #108
ryans88gt's Avatar
Did you make sure the metal bushing was still on the planetary gear? They will have a little tiny bit of play, but not much.
Old September 28th, 2010, 06:54 PM   #109
yea the bushing are there in both tired shimming the side gears more and when i do that it pops the bushing off the spider gears when i go to rotate them back into the housing so i dont think that i can shim the side gears anymore.
Old September 29th, 2010, 01:41 PM   #110
ryans88gt's Avatar
Sounds good then.
Old September 30th, 2010, 02:51 AM   #111
MATT02GT's Avatar
MATT02GT is a jewel in the roughMATT02GT is a jewel in the roughMATT02GT is a jewel in the roughMATT02GT is a jewel in the rough
Great writeup, but the pics wernt showing up for me anymore.
Bolt on list in Garage..
Old September 30th, 2010, 01:15 PM   #112
ryans88gt's Avatar
The pics have been moved to page 4 or 5
Old October 1st, 2010, 08:33 PM   #113
2000 mustang v6
GOLDSTANG is on a distinguished road
quick question here guys do any of you know if the rear end out of an explorer fit 2000 v6 mustang
Old October 3rd, 2010, 04:09 PM   #114
how much clearance should there be between center pin and axles
Old October 4th, 2010, 01:21 AM   #115
ryans88gt's Avatar
There is an end play spec, but I don't know what it is. I like them to be as close as possible without causing the center pin to bind when you install it, since the end play will go up as the clutch packs wear.
Old October 9th, 2010, 11:08 PM   #116
Look Ma! My First Post!
annodekim is on a distinguished road
Traction Lok
This was a fantastic writeup! I humbly admit to not owning a Stang but the diff is the same as my old Ranger 4x4. To change a leaking axle oil seal I found I had to take apart the diff to get at the C-clips which is fine, but is there a fix for getting the pin all the way out so I can remove the S-spring? With the spring in the way I cant get at the C-clips (my axles dont seem to push in as far as yours). The pin cant clear the ring gear because the pin's flat-edge ends. At that point there's about 2mm of overlap where the pin's full diameter comes into contact with the ring gear and I'm sure smashing the ring gear in frustration is NOT the correct approach.
Old October 11th, 2010, 09:42 AM   #117
moneymo's Avatar
1991 Mustang Gt 5.0
moneymo is on a distinguished road
Awesome write up.
Old November 6th, 2010, 03:13 PM   #118
99 Cobra - 92 LX - 90 LX
pacopatron is on a distinguished road
Awesome write up! What happened to all the pics?
Question:
What does single life get you?
Answer:
  • 1999 Mustang Cobra
  • 1992 Mustang LX Vert
  • 1990 Mustang LX
Old December 7th, 2010, 06:07 AM   #119
89drop's Avatar
1989 GT convertible
89drop is on a distinguished road
GREAT!!! im going to add this to my winter projects since im going to have the rearend apart anyway!
Old December 7th, 2010, 06:14 AM   #120
2000 gt
Everett will become famous soon enoughEverett will become famous soon enough
awesome write up....STICKIE
Black and White Crew
Crew Member # 3
centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/58740-trac-lok-rebuild-how.html
clutches in a ford 8.8 question | Mustang Forums at StangNet This thread Refback December 4th, 2011 11:41 PM
TracLok Rebuild - FFCars.com : Factory Five Racing Discussion Forum This thread Refback November 16th, 2011 02:51 PM
Vehicles that have 4.10 Gears at junkyard - Page 2 - Lincoln vs Cadillac This thread Refback October 25th, 2011 09:23 PM
??? about stock rearend in a 1991 - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback August 24th, 2011 11:58 AM
Thread Trac-Lok rebuild how to. - Page 5 | Forums at Modded Mustangs | BoardReader This thread Refback June 14th, 2011 01:58 PM
TurboFord.org Forums: Any good write ups online for 8.8 trac loc freshenings? This thread Refback June 13th, 2011 05:53 AM
Rebuilt my trac-loc today....... - Ford Mustang Forums : Corral.net Mustang Forum This thread Pingback June 4th, 2011 05:33 PM
Removing Limited Slip Pin for Clutch Replacement This thread Refback May 30th, 2011 07:42 PM
T-lok HELP ASAP!!! This thread Refback May 25th, 2011 07:29 AM
how to get out S spring This thread Refback May 19th, 2011 01:47 PM
Ford 8.8 Axle - Page 2 - Pirate4x4.Com Bulletin Board This thread Refback April 21st, 2011 05:26 AM
clutches in a ford 8.8 question - Mustang Forums at StangNet This thread Pingback April 19th, 2011 03:32 AM
Trac Lok | Reference.com This thread Refback March 24th, 2011 02:44 AM
Ford 8.8 Axle - Page 2 - Pirate4x4.Com Bulletin Board This thread Refback March 9th, 2011 05:46 PM
??? about stock rearend in a 1991 - Corral.net : Ford Mustang Forums This thread Refback January 10th, 2011 08:23 PM
Traction loc rebuild - Four Eyed Forums This thread Refback January 8th, 2011 11:27 AM
Traction loc rebuild - Four Eyed Forums This thread Refback January 7th, 2011 11:16 PM
Traction loc rebuild - Four Eyed Forums This thread Refback January 7th, 2011 11:02 PM
Info.com - trac loc - www.Info.com This thread Refback November 1st, 2010 01:22 PM
TracLok Rebuild - FFCars.com - Factory Five Racing Discussion Forum This thread Refback August 15th, 2010 05:39 PM
Ford Mustang Forums - View Single Post - 3.73 t-lok rebuild? This thread Refback June 26th, 2010 10:12 PM
8.8 Rebuild - Vancouver Mustangs This thread Refback June 16th, 2010 08:57 PM
8.8 Rebuild - Vancouver Mustangs This thread Refback June 16th, 2010 03:39 AM
8.8 Rebuild - Vancouver Mustangs This thread Refback June 15th, 2010 10:14 PM
8.8 Rebuild - Vancouver Mustangs This thread Refback June 15th, 2010 10:11 PM
8.8 Rebuild - Vancouver Mustangs This thread Refback June 15th, 2010 08:47 PM
8.8 Rebuild - Vancouver Mustangs This thread Refback June 15th, 2010 06:18 PM
rebuilding differential,ne websites with step by step instructions?ne 1 know how This thread Refback May 10th, 2010 03:43 PM
Rio's 8.8 - Links4Jeeps.com This thread Refback May 2nd, 2010 09:39 PM
Rio's 8.8 - Links4Jeeps.com This thread Refback May 2nd, 2010 09:22 PM
Info.com - trac lok - www.Info.com This thread Refback April 6th, 2010 12:30 PM
8.25 trac lock install - JeepForum.com This thread Refback March 31st, 2010 11:00 PM
Rio's 8.8 This thread Refback March 7th, 2010 10:47 PM
Rio's 8.8 This thread Refback February 24th, 2010 10:04 PM
TracLok Rebuild - FFCobra.com - Factory Five Racing Discussion Forum This thread Refback February 3rd, 2010 12:49 PM
TracLok Rebuild - FFCobra.com - Factory Five Racing Discussion Forum This thread Refback February 3rd, 2010 12:39 PM
Rio's 8.8 This thread Refback January 2nd, 2010 04:23 PM
97 Cobra Differential problem - SVTPerformance This thread Pingback January 2nd, 2010 12:32 PM
How-To: Ford 8.8 This thread Refback December 9th, 2009 07:41 PM
Difflock :: View topic - Ive defected lol ,now a jeep owner This thread Refback November 17th, 2009 03:57 PM
How-To: Ford 8.8 This thread Refback November 16th, 2009 07:25 PM
Difflock :: View topic - Ive defected lol ,now a jeep owner This thread Refback November 16th, 2009 04:21 PM
Difflock :: View topic - Ive defected lol ,now a jeep owner This thread Refback November 15th, 2009 11:14 PM
trac lok rebuild kit?? will it work - Ford Explorer Ranger Enthusiasts This thread Refback November 15th, 2009 01:48 PM
Ford 8.8 Axle - Page 2 - Pirate4x4.Com Bulletin Board This thread Refback November 12th, 2009 06:19 PM
Trac-loc rebuild ? - GrandMarq.NET - Panther Headquarters This thread Refback November 2nd, 2009 08:26 PM
Trac-loc rebuild ? - GrandMarq.NET - Panther Headquarters This thread Refback November 2nd, 2009 02:32 PM
T-Lok clutch packs bad - Mustang Forums at StangNet This thread Refback November 1st, 2009 08:58 PM
Trac-loc rebuild ? - GrandMarq.NET - Panther Headquarters This thread Refback November 1st, 2009 08:27 PM
trac lok rebuild kit?? will it work - Ford Explorer Ranger Enthusiasts This thread Refback November 1st, 2009 12:15 AM
Rio's axle questions This thread Refback October 25th, 2009 05:52 PM
Improving OEM Limited Slip/Upgrade...? - Page 3 This thread Pingback October 23rd, 2009 01:19 PM
Rio's axle questions This thread Refback September 13th, 2009 07:09 PM
Rio's axle questions This thread Refback September 13th, 2009 05:36 PM
Rio's axle questions This thread Refback September 13th, 2009 01:10 AM
Rio's axle questions This thread Refback September 13th, 2009 12:43 AM
Not a good day for the 93 GT..... - Corral Forums This thread Refback August 15th, 2009 08:36 AM
Not a good day for the 93 GT..... - Corral Forums This thread Refback August 14th, 2009 08:04 PM
Killed a Subaru SVX V6 - Page 2 - Superiorstangs This thread Refback July 27th, 2009 03:21 AM
Another new member in the Albany, OR area - Page 2 - Superiorstangs This thread Refback July 1st, 2009 04:55 AM
rebuilding differential,ne websites with step by step instructions?ne 1 know how This thread Refback June 27th, 2009 06:10 PM
Differential Trac-lok Oil Required on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback June 26th, 2009 07:02 AM
UC4x4 Official Forum - View topic - rear axle purchase discussion This thread Refback June 26th, 2009 06:17 AM
18x9 Saleens - Photoshop? - Page 2 - Superiorstangs This thread Refback June 2nd, 2009 12:53 AM
Removing Limited Slip Pin for Clutch Replacement - 3.8 Mustang Message Board This thread Refback May 20th, 2009 12:01 PM
??? about stock rearend in a 1991 - Corral Forums This thread Refback April 27th, 2009 10:37 PM
Removing Limited Slip Pin for Clutch Replacement - 3.8 Mustang Message Board This thread Refback April 23rd, 2009 10:31 PM
Removing Limited Slip Pin for Clutch Replacement - 3.8 Mustang Message Board This thread Refback April 12th, 2009 09:37 PM
??? about stock rear end in a 91?/? - Corral Forums This thread Refback April 11th, 2009 10:37 PM
Removing Limited Slip Pin for Clutch Replacement - 3.8 Mustang Message Board This thread Refback March 30th, 2009 03:27 PM
Removing Limited Slip Pin for Clutch Replacement - 3.8 Mustang Message Board This thread Refback March 28th, 2009 07:46 PM
Removing Limited Slip Pin for Clutch Replacement - 3.8 Mustang Message Board This thread Refback March 28th, 2009 02:09 AM
posi rebuild This thread Refback March 22nd, 2009 04:15 AM
3.73 t-lok rebuild? - Ford Mustang Forums This thread Refback March 18th, 2009 12:59 AM
T-lok HELP ASAP!!! - 3.8 Mustang Message Board This thread Refback March 16th, 2009 06:09 AM
T-lok HELP ASAP!!! - 3.8 Mustang Message Board This thread Refback March 15th, 2009 10:13 PM
Limited-slip musings - Page 2 - GrandMarq.NET - Panther Headquarters This thread Refback January 17th, 2009 01:42 AM
Traction Lok rebuild....... - UnitedStangs.com This thread Refback December 28th, 2008 12:16 AM
Traction Lok rebuild....... - UnitedStangs.com This thread Refback December 27th, 2008 01:38 PM
t-lok and one wheel wonders - 3.8 Mustang Message Board This thread Refback December 8th, 2008 12:46 AM
t-lok and one wheel wonders - 3.8 Mustang Message Board This thread Refback December 7th, 2008 11:52 PM
t-lok and one wheel wonders - 3.8 Mustang Message Board This thread Refback December 7th, 2008 11:13 PM
factory limited slip in 8.25 This thread Refback October 2nd, 2008 10:33 PM
how to get out S spring - ModularFords.com This thread Refback September 26th, 2008 09:31 AM
how to get out S spring - ModularFords.com This thread Refback September 26th, 2008 04:13 AM
Trac-Lok rebuild how to. This thread Refback September 21st, 2008 11:41 AM
Latest posts of: tolow4phathoess This thread Refback July 16th, 2008 12:47 AM
Ford 8.8 Axle - Page 2 - Pirate4x4.Com Bulletin Board This thread Refback June 27th, 2008 02:26 PM
Ford 8.8 Axle - Page 2 - Pirate4x4.Com Bulletin Board This thread Refback June 27th, 2008 02:08 PM
TurboFord.net Forums: Any good write ups online for 8.8 trac loc freshenings? This thread Refback June 22nd, 2008 07:09 AM
TurboFord.net Forums: Any good write ups online for 8.8 trac loc freshenings? This thread Refback June 17th, 2008 12:43 AM
TurboFord.net Forums: Any good write ups online for 8.8 trac loc freshenings? This thread Refback June 16th, 2008 11:04 AM
zatzy racing community - Ford mustang -87 This thread Refback May 26th, 2008 05:16 PM
Sometimes my GT just makes one tiretrack... :( This thread Refback May 26th, 2008 02:02 AM
Trac-lock rebuild This thread Refback May 17th, 2008 05:54 PM
Trac-lock rebuild This thread Refback May 11th, 2008 09:57 PM
8.25 trac lock install - JeepForum.com This thread Refback May 10th, 2008 10:57 PM
Trac-lock rebuild This thread Refback May 5th, 2008 09:15 PM
Trac-lock rebuild This thread Refback May 5th, 2008 07:24 AM
Trac-lock rebuild This thread Refback May 5th, 2008 05:55 AM
8.25 trac lock install - JeepForum.com This thread Refback March 22nd, 2008 05:22 PM
Threads Similar to: Trac-Lok rebuild how to.
trac off blazor V6 Mustangs 6 January 13th, 2008 08:36 PM
trac off blazor General Tech 1 January 13th, 2008 04:39 AM
Trac-Lok Kennhyy3 V6 Mustangs 7 April 20th, 2007 10:09 PM
Trac lok postie V6 Mustangs 13 December 29th, 2006 01:24 AM
Trac Off stanged out V6 Mustangs 22 November 21st, 2006 03:31 PM
