Edelbrock Carb Problems!?!?!?
Old March 5th, 2008, 12:35 AM   #1
Mike Johnson's Avatar
1997 Mustang V6
Mike Johnson is on a distinguished road
Send a message via AIM to Mike Johnson Send a message via Yahoo to Mike Johnson
Question
Alright I have an edelbrock 750 on my 5.0 and its just not working right. I cranks pumps fuel in and it sometimes will start and sometimes it won't. I've messed with the timing, adjusted the idle air screws to the best of my knowledge. Most the time when it starts it will back fire or run for a few seconds and die. I've had it running for a little bit once and checked the fuel pressure and its right at 6.5psi. Also the #3&7 header tube on each side was glowing red, I don't think it was running lean but the timing was too retarded.
I had a holley 600 on it before and it ran fine until fuel started leaking into the carb somewhere from the secondary bowl. I took it off because it was leaning out at the top end. So, I don't think anything internally was messed up since it was running off the holley.
97 Coupe 3.8L V6 5spd | Daily Driver
01 F-250 7.3L Diesel 6spd | Expensive Daily Driver
Old March 5th, 2008, 12:53 AM   #2
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
750 is too big for a 5.0... u should have rebuilt the holly
<font size=4><b>MILITARY CREW
Old March 5th, 2008, 01:09 AM   #3
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
edelbrock makes great intakes, but carbs ? eeeehhhhhh.........
Old March 5th, 2008, 10:38 AM   #4
02 Mustang GT
Cant wait to find out
Black Five 0h is on a distinguished road
+12434345345647 WAY too big
02 Mustang GT
"We build it up, run it hard, we know whats breaking and we enjoy it breaking, we dump money into it, we re-build it stronger, run it harder in anticipation of it breaking again. We are sick individuals."
Old March 5th, 2008, 06:45 PM   #5
1997 Mustang V6
Well my holley is is cracked. And I'm going to be running nitrous so thats why I have the 750 on there, and I plan to use it on the next engine I build for the car.
Old March 5th, 2008, 09:26 PM   #6
1987 ford mustang gt
well see when shes done
edelbrock= shiny carter afb
Old March 6th, 2008, 02:05 AM   #7
ryans88gt's Avatar
glowing headers = unburned fuel...could be rich or it could be not enough timing.
If you timing is off it is hard to set up a carb. If you can get it running for a minute, set the timing. Then start worrying about the carb.
Old March 6th, 2008, 07:01 PM   #8
1997 Mustang V6
We had the thing running for a little while and it was idling fine then I went to put a timing light on it and before I could it died and wouldn't start back up and stay running.
Old March 6th, 2008, 07:29 PM   #9
ryans88gt's Avatar
First thing is to check to make sure you are still getting fuel and spark. If yes, mark your current dist. position and turn the distributor slightly clockwise 1/32" or so and try to start again. If no start, turn some more. If still nothing after a few trys go the opposite direction. Eventually you should find timing that it will run long enough at to set the timing.
Threads Similar to: Edelbrock Carb Problems!?!?!?
edelbrock Mustang RacR94 4V / SVT 1 February 18th, 2008 12:33 PM
edelbrock Mustang RacR94 99-04 4 February 17th, 2008 08:24 PM
Edelbrock zinc02GT The Clubhouse 11 January 22nd, 2008 12:28 AM
bbk and edelbrock cali 5.0 General Tech 0 October 14th, 2007 11:34 PM
Edelbrock Adj. Uppers has anyone used these? C MY 4D Parts 2 May 21st, 2007 03:41 PM
