Discussing Supercharged now what? in the 5.0 Mustangs Forum. I want to do much as possible with out changing the bottom end like crankshaft, ...
Old March 10th, 2008, 04:24 PM   #21
1987 Mustang GT
I want to do much as possible with out changing the bottom end like crankshaft, pistons, rods etc..
Old March 10th, 2008, 06:38 PM   #22
Hunt_chevs's Avatar
88 Gt
Not Slow
gears 1st,...than more boost.you can safely run more psi on stock block etc. i believe about 8psi... i wouldnt go much more than that. and than get a throttle body and a pair of nice intakes. that should funnel in the air more efficiently.
Old March 10th, 2008, 11:59 PM   #23
Stangzilla's Avatar
Originally Posted by chadscharged50 View Post
Ford motorsport Powerdyne 5psi
5psi?!! I can blow harder than that... I would have bought the Trick Flow HCI combo and you would have been better off...
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.”
Old March 11th, 2008, 12:01 AM   #24
Stangzilla's Avatar
A nice pair of intakes? We are talkin about a 5.0 right?
Old March 11th, 2008, 05:11 AM   #25
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
I know one 89 that has run 11psi with Powerdyne many years, stock internals, ported e7s and better head gaskets, but i dont remember what they were anymore. I talked to him before i choosed to supercharge my car.
Old March 11th, 2008, 10:25 AM   #26
nolife's Avatar
I have been running 10-12 on a stock bottom end for a while now in my 88 GT and an unknown amount of time before I bought it. It is a Ford Motorsport 5.0 crate engine but the short block is basically the same thing as every other 5.0. The head gaskets are fine and my compression tests have been very consistent (about 175 +-5 across all cylinders). Although I have no indication of excessive blow-by, I have issues with oil "seepage" from just about every sealing surface. I don't know if that is normal for a boosted car or not but I think the car sat for a while because the rubber valve cover gaskets were dry and hard. I assume the other sealing surfaces are shot as well.
1991 GT - Original owner, all stock
1988 GT - The project car
Old March 11th, 2008, 03:36 PM   #27
Iwannagofast's Avatar
1990 Mustang GT
9.39@76.09----1/8th mile
ok well he definitely doesnt have to worry about the block yet......it doesnt take a whole lot to break the tranny though.....but will that blower a WC t5 would be fine if his does go out......
yeah i would go suspension first and gears.....then maybe start lookin into top end stuff
stang=40's dumped,pro 5.0 short throw, king cobra clutch, adj. clutch cable and firewall adjuster...pretty much stock
2001 tacoma=magnaflow, K&N cai, tb spacer, 2.5" susp. lift, 32x11.50s, electric fan, few dress up items
Old March 11th, 2008, 06:11 PM   #28
fogged306's Avatar
89 GT
You can blow harder than 5psi? .... are you free this evening?
Old March 11th, 2008, 07:14 PM   #29
1990 Mustang GT
he walked into that one.....lol
Threads Similar to: Supercharged now what?
supercharged bobb17 2.3 Mustangs 6 March 3rd, 2008 02:16 PM
supercharged Black Five 0h 5.0 Mustangs 3 July 23rd, 2007 03:52 PM
Supercharged shadowgames81 Poweradders 4 February 8th, 2007 08:36 PM
Supercharged? kerry V6 Mustangs 10 November 22nd, 2006 12:57 AM
supercharged mustangdrvr2019 V6 Mustangs 1 September 12th, 2006 01:49 AM
