Discussing 302 Turbo in the 5.0 Mustangs Forum. kk for the guys who know thier boost how well do you think i can ...
Old October 3rd, 2006, 08:25 PM   #1
302 Turbo
kk for the guys who know thier boost how well do you think i can do with a 66mm turbo charged setup both stock block with stock heads and built block estimates.. hp and track time thanks..
Old October 3rd, 2006, 08:58 PM   #2
Moderator
89StangGT's Avatar
what kind of built block? compression ratio? cam size? lift? duration? Valves? Intake/throttlebody ect? more info is needed for any kind of guess for hp. as for times, what does the car weigh? what trans? what rear end and gear ratio? you need a lot more info man you cant expcet us to guess what you have and pull out a number
I NEED A NEW MUSTANG PROJECT!
1987-1993 ROLLER WANTED!
BRING SLICKS..NOT EXCUSES
Old October 3rd, 2006, 08:59 PM   #3
im talking about stock stock stock for now because i hear you can run these things to the tits stock untill it blows you have any ## stock or will i have to ask my shop?
Old October 3rd, 2006, 08:59 PM   #4
Moderator
89StangGT's Avatar
also your not gonna make much power with stock heads they flow like garbage without work done, and what yr block and heads?
Old October 3rd, 2006, 09:00 PM   #5
Moderator
89StangGT's Avatar
best bet is to ask the shop, since they know what all exacly is going into the build they should beable to tell you with no probs.
Old October 3rd, 2006, 09:03 PM   #6
kk thanks n yea i know the heads suck with flow im going to invest into afrs
Old October 3rd, 2006, 09:09 PM   #7
im thinknig about afr 185cc heads
Threads Similar to: 302 Turbo
Turbo is done, got a question for you turbo guru's Regency 2007 2005+ 33 June 26th, 2007 08:46 AM
Supercharger, Twin Turbo, and Single Turbo justinsstang Poweradders 24 March 7th, 2007 09:07 PM
Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 Mellon Videos 10 December 30th, 2006 10:05 AM
Turbo, Twin Turbo, Procharger, or Kennebell? black94gt 5.0 Mustangs 19 October 7th, 2006 10:41 AM
Super Charger vs Turbo/Twin Turbo: Pros and Cons of each FireryDriver 2005+ 9 September 17th, 2006 04:15 PM
