87 Ford Mustang, Replaced clutch fork cable. were do i ajust - Forums at Modded Mustangs
post #1 of 6 Old October 3rd, 2006, 10:12 PM Thread Starter
Look Ma! My First Post!
I have a 87 Ford Mustang, recently the clutch fork cable broke itís about 2 inches long and i replaced it. now peddle is all the way at top no play. How do i adjust it so that my clutch wont start to slip? I cannot find the clutch adjustment. Can anyone help?
luner35 is offline
post #2 of 6 Old October 9th, 2006, 03:57 PM
if you're still using the stock cable...SOL. if you have an aftermarket cable the adjustment is made at the clutch fork end of the cable, just loosen the nut(s) and retighten them further back on the cable.
89 GT t5 3.73
www.my5oh.com/
TENGRAM is offline
post #3 of 6 Old October 14th, 2006, 12:21 AM
stang fanatic's Avatar
IF the auto adjust still works, pull the pedal all the way up, then push down and see what happens. if it still works it should make a ratcheting sound
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
stang fanatic is offline
post #4 of 6 Old October 21st, 2006, 01:56 PM
i would suggest gettin a upr adjustable cable and new quadurant. Cause one day the stock one will leave you stranded. It happend to me. And if you ever plan on getting a heavy duty clutch you need a heavier duty cable and quadurant anyways.
96gt is offline
post #5 of 6 Old January 5th, 2007, 03:26 AM
My problem is almmost similar. The clutch has been replaced about 5000 miles. Now it is very hard to put it in 1st gear unless the pedal down deep to the floor. What could happenning? I have an 87 LX 5.0
1987 LX 5.0 Coupe AT
dave0970 is offline
post #6 of 6 Old March 4th, 2007, 02:23 AM
change the cable it is cheap insurance I did my tibird
dlaughman is offline
Human Verification
