Vapor Locking?
Old October 3rd, 2006, 11:35 PM   #1
blackhd is on a distinguished road
Vapor Locking?
My daughters 88 5.0 gt sputtered and quit at an intersection. She had just left a store where she left it idling w/ac (friend&baby). It started up again after a while but only went a block and did the same. I went to look at it and it would start and run for a while and then start sputtering and die like it was running out of gas. Tank is full. After it got cold, I drove it around the block with no problems. Has anyone ever had vapor lock problems with the 5.0? I thought I could hear something(hissing?) around the gas line on top of the engine when it was hot and motor was off. I don't know where to start to troubleshoot a problem like this. Please help.
Thanks
Old October 4th, 2006, 04:27 PM   #2
cali 5.0 is on a distinguished road
check the fuel pressure, since u hear hissing coming from the fuel line the pressure is obviously too high if tht is where its coming from, u might hav a pinched fuel line somewhere, check the pressure it should be around 40psi maybe a little more or less,.... might wanna change the fuel filter also..
Threads Similar to: Vapor Locking?
Need help locating the Vapor Canister Purge Valve dbrown6007 99-04 6 May 26th, 2009 10:17 PM
Vapor Air Canister stanglover99 99-04 2 July 25th, 2007 03:46 PM
stg.8 locking header bolts Invictus 99-04 1 June 18th, 2007 05:07 AM
Manually Locking TQ Converter Juggalo_X V6 Mustangs 4 May 29th, 2007 08:47 PM
Vapor filter?? AnglicoGT98 96-98 6 May 26th, 2007 12:15 PM
