Discussing 5.0 Tech Article Directory in the 5.0 Mustangs Forum. This is a temperary listing of the 5.0 Tech related articles. Keeping them in ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Maintenance Man
11.47@120.58
5.0 Tech Article DirectoryPiston to Valve Clearance Head Porting Info Detonation and Preignition AOD to T5 Conversion Vortech Supercharger Rebuild Cleaning the Mass Airflow Sensor (MAF) Valve Lash Adjustment Brake Upgrade Information Setting Idle for a 5.0 |
Site Moderator
1999 Ford Mustang V6
14.79 @ 92.15
just a heads up, degreeing a camshaft is on there 3x. i like the idea of organizing the links into one stick post too
1999 Mustang V6 I used to list my mods here but stopped when I exceeded 255 characters.
Maintenance Man
11.47@120.58
fixed. thanks.
looks much better.
Moderator
i thought we had an article on here on how to set the TPS. guess not.
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!! |
1993 Cobra
Hey I have a 93 Cobra and was wandering if anyone came across the problem of a/c not blowing through the vents its stuck blowing floor and def. Not sure if its the vacuum or switch. Also I have a problem with my relay heating up so hot I cant touch it unless the car has been off for an hour or two. Anyone know whats up with either of these problems?
Originally Posted by riddlee josh what exactly is vtec?very tall engine coolant
Look Ma! My First Post!
are there any mustang 5.0 people in the vegas area willing to help on a project ? just with questions about the fuel injection and general hop up parts for the motor, thanks jason
#9 | |
...even fire and single cammin |
nice
This is usually a sign of some sort of vacuum failure or leak. On my 91 LX, there is a vacuum hose block behind the dash between the glove box door and the center console. It should have several different color hoses going into it. Make sure that they are all connected and to the correct outlets. There is also (on mine) a little discussed vacuum resevoir located in the passenger side wheel well (behind the plastic inner fender liner). Not wanting to pull the inner fender apart at that time, I picked up a new one from Ford (no it wasnt obsolete yet!) and just hooked it up under the hood. Like magic, the whole hvac system came back to life! When I did my front suspension, I pulled the inner fender liner and found that the resevoir had a 3 inch split right along the seam. Hope this helps.
nice thanks
exhaust pic request
Ignore this. Meant to start new thread.
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
Last edited by tehdwarvenn : February 19th, 2008 at 09:49 PM. Reason: Messed up -_- |
exhaust pic request
Double post sorry.
1981 Capri
I've got what may seem to be a really dumb question...on a 82 5.0 litre engine 302 CID what would have been the Horse power and Torque for that engine
95 opalfrost gt
so much information in this link that It should be a sticky by itself.
Mustang FAQ - Engine Information
Threads Similar to: 5.0 Tech Article Directory
| Classic Mustang Tech Topics Directory | Horseshoeing | Classic Mustangs | 0 | March 27th, 2007 08:50 AM |
| ATF Fluid in T5 Transmission? From Tech Article | 83 5.0 | 5.0 Mustangs | 12 | August 29th, 2006 10:26 AM |
