TFS And Rockers
Old October 5th, 2006, 11:35 PM   #1
jetpilot106 is on a distinguished road
TFS And Rockers
im going 2 order some tfs twisted wedge heads and stage 1 cam,i was wondering if i could use the 1.7rr on them
Old October 5th, 2006, 11:42 PM   #2
mdvaldosta's Avatar
11.47@120.58
What are the specs on the cam? Usually folks choose a cam based on the stock 1.6 ratio...
Old October 6th, 2006, 12:45 AM   #3
it had a .499 lift i was thanking i could use the 1.7s 2 get somemore lift out of it i kind of figured i might have some ptvc problems with that
Old October 6th, 2006, 06:15 PM   #4
Zak
Zak is on a distinguished road
TFS Track Heat stage 1 is good for stock engines with a performance close to Ford Racing E303 camshaft.. they have I/E durations of 221/225 @ .050" valve lifts, .499 / .510 lifts on I/E with 1.6 ration rockers, and LSA of 112 with intake centerline at 107 crank degrees.
With 1.7 RR you will get .530 / .542 lifts.. I don't know if the stock flat pistons have valve reliefs to accept this lift, but I personally doubt it.
Old October 6th, 2006, 10:17 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I've run .600 lift successfully in the past with TFS heads and stock pistons BUT I've also had a stock engine that wouldn't clear an E303 cam. Valve to piston clearance always should be checked to be safe.......or you can play the lottery....
Old October 6th, 2006, 11:54 PM   #6
5-0stank is on a distinguished road
roll the dice, haha
1995 GT::Sold!
Looking for another stang...
Old October 7th, 2006, 01:58 PM   #7
Zak
Different cams have different timings and it all depends on what degree of the crankshaft does valve-lifting take action, and also for how long... I think this is why a stock 5.0 piston with stock valves may accept a cam with .600" lift but not another one with .499"
I believe there has to be a theoritical way to know -from the cam card- if the PTVC would be OK or not, and the practical checks later will just confirm it.
Threads Similar to: TFS And Rockers
Rockers javier351lx 5.0 Mustangs 10 October 8th, 2007 11:21 AM
oem rockers? superman5.0 5.0 Mustangs 2 August 7th, 2007 07:37 PM
what rockers? marks87gt 5.0 Mustangs 25 April 11th, 2007 12:52 AM
rockers DragonFreak 96-98 4 April 4th, 2007 02:11 PM
rockers... Fastpitchdad 5.0 Mustangs 2 November 28th, 2006 10:08 PM
