86 GT wont fire
Old March 15th, 2008, 04:18 PM   #1
alabamastanger's Avatar
1983 Mustang GT
N/A
alabamastanger is on a distinguished road
86 GT wont fire
My buddy tore the top part of the engine down to freshen it up, but after we got it all back together, it will not fire/start. It will turn over fine, but there is not firing. The distributor and all of the spark plugs are fine. The fuel pump is coming on. He did take the fuel rails off, so could that be the problem? I saw that the MAP sensor wasn't plugged in and thought I had found it, but it still won't start. We need help.
Old March 15th, 2008, 04:39 PM   #2
86ttops's Avatar
86,97 mustang gt t tops
n/a
86ttops will become famous soon enough
Send a message via Yahoo to 86ttops
I would say tripple check all the wiring make sure the coil is getting power to start. Fuel rails shoudnt have anything to do with firing
Old March 15th, 2008, 06:14 PM   #3
teal89's Avatar
89 Mustang Lx
teal89 is on a distinguished road
Make sure the plug on the dizzy is in good and what he said above. Be sure your not 180 out or whatever. Check that your coil is still good and/or if you have an MSD box, check that it works as well
94-95 306, B-Cam, Off-brand BBK Like Headers, H-Pipe, 3.73's, Nitrous Wet Shot 175 Shot
Old March 15th, 2008, 06:17 PM   #4
fogged306's Avatar
89 GT
So you've checked at the plugs and are getting spark?.. If so I would check the fuel pressure too... but I'm leaning to an ignition problem.
Threads Similar to: 86 GT wont fire
Miss-fire. RAGEman 99-04 6 February 17th, 2008 11:26 PM
Trying to get my 347 to fire, Help please! problemCOBRA94 5.0 Mustangs 56 January 26th, 2008 08:31 AM
Fire In A 66 460brevill Classic Mustangs 10 December 3rd, 2007 11:46 PM
MY FORD LASER JUST STOPPED FOR NO REASON - WONT FIRE -HELP molly New Members Introductions 3 September 6th, 2007 10:56 AM
Fire came out of my tailpipes!?!?!!? Jeff99gt 99-04 35 June 10th, 2007 11:32 AM
