How Do I Prime An Oil Pump
Old March 17th, 2008, 10:50 PM   #1
armalpass96 is on a distinguished road
How do i prime my oil pump...i know it involves removing the distributor and using a drill somehow...Or can i just turn the motor over without the coil plugged in because the bottom end has been run but its been at least 2 years.
Old March 17th, 2008, 10:56 PM   #2
fogged306's Avatar
89 GT
To use a drill you need a spare distributer shaft and you modify it to fit in the chuck of the drill.. I've never actually done it so this is secondhand knowledge, but I have actually seen it done. There may be other ways too, I'm sure someone else will chime in.
Old March 17th, 2008, 11:16 PM   #3
woody1 is on a distinguished road
1/4 inch socket taped to a long 1/4 inch extension, chuck in the drill and run it counterclockwise.
Old March 17th, 2008, 11:47 PM   #4
e3sean's Avatar
1988 lx
9.68@142
+1 thats how i did mine
<font size=4><b>MILITARY CREW
Old March 18th, 2008, 11:13 AM   #5
87 'Stang
13.1@105
wade95 is on a distinguished road
Heck, I went out and actually bought the priming tool, but the other things that were mentioned will work out fine.
If it's been two years I say spin it until you get oil up to the heads, turn the crank over 180* and do it again,,,just to be safe.
87 Hatch. Holley Systemax Kit. F cam. No AC, PS and front swaybar. Built rearend. 310hp/308tq.
Old March 18th, 2008, 11:29 AM   #6
alright ..will do...thanks for the help
Threads Similar to: How Do I Prime An Oil Pump
2007 Pump Gas Drags 32 of the fastest pump gas cars Mellon Videos 7 June 14th, 2008 12:08 PM
oil pump mpboy 99-04 4 February 17th, 2008 07:54 PM
Mechanical pump, or existing in-tank pump? shnipplelicken 5.0 Mustangs 7 July 11th, 2007 11:47 PM
svt focus pump vs. ford GT pump undomesticfire 99-04 3 May 15th, 2007 07:10 PM
A1000 Pump With 255lph In-Tank Pump ? 92lx5oh 5.0 Mustangs 11 March 18th, 2007 08:51 PM
