Head Swap
Old October 9th, 2006, 08:27 AM   #1
wikdsvt is on a distinguished road
Head Swap
My car was overheating and I decided it was the head gasket (the nitrous was the catalyst). So since I was breaking into the engine I decided to swap gt40p heads(ported/polished), 1.7 sharp rockers, typhoon intake, mac 70mm throttle, fms gt40p headers, underdrive pulleys,and delete the smog pump(shorter belt). Well after swapping everything the starter was sounding really bad. I decided to change the starter relay, starter, battery, and when trying to start the noise is a rapid tapping. I believe it is the new starter trying to work. I have fuel pressure, but I think the distributor may be the problem. I marked the distributor when I removed it from the engine, but the manual says to make sure piston #1 is TDC and to align the distributor to that. Any ideas of where to go next to get my stang back running?
Old October 9th, 2006, 02:50 PM   #2
KJeezy is on a distinguished road
If the starter isn't turning the engine it's not getting enough juice. Sounds to me like you're describing a low voltage condition.
Old October 9th, 2006, 08:36 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Or the engine is hydrolocked....
Old October 9th, 2006, 10:38 PM   #4
niggadrew's Avatar
niggadrew is on a distinguished road
rapid tapping .... check the tappets and make sure they are spaced right
well shit this town aint big enuf for the both of us
Old October 10th, 2006, 04:15 PM   #5
5-0stank is on a distinguished road
make sure the tappets are spaced right??? tappets go in the block, no?
1995 GT::Sold!
Looking for another stang...
Old October 10th, 2006, 07:19 PM   #6
niggadrew's Avatar
tappets cam folowers yea ......
Threads Similar to: Head Swap
PI Head Swap and Transmission Swap jEEd 96-98 18 May 14th, 2009 01:57 AM
4.6L PI Head Swap Kit slvrbllt98GT 96-98 5 June 14th, 2007 04:29 PM
head swap Mustang RacR94 99-04 9 April 25th, 2007 06:27 PM
Cam and head swap I need help!!!!! Kevin b 5.0 Mustangs 19 January 3rd, 2007 01:30 AM
5.4L Head swap??? rwk3072 96-98 7 July 23rd, 2006 01:40 AM
