Discussing Manifold Installation in the 5.0 Mustangs Forum. i have asked many questions on how to install things on this forum and someone ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
http://img.photobucket.com/albums/v1...eLot/stang.jpg |
1994 Mustang GT
ukn
I hope this helps, good luck and it is not as bad as it looks like.
UPPER EASY LOWER- 18. Apply a 3/16 in. (5mm) bead of sealer to the outer end of each intake manifold seal for the full width of the seal. Make sure the silicone sealer will not fall into the engine and possibly block oil passages. 19. Using guide pins to ease installation, carefully lower the intake manifold into position on the cylinder block and cylinder heads. After the intake manifold is in place, run a finger around the seal area to make sure the seals are in place. If the seals are not in place, remove the intake manifold and position the seals. 20. Make sure the holes in the manifold gaskets and the manifold are in alignment. Remove the guide pins. 21. Install the intake manifold attaching bolts and tighten, in 3 passes of the sequence: 1. First tighten to 8 ft. lbs. (11 Nm). 2. Then tighten to 16 ft. lbs. (22 Nm). 3. Finally, tighten the bolts to 23-25 ft. lbs. (31-34 Nm). 22. Install the heater tube assembly to the lower intake manifold studs. 23. Install the water pump bypass hose on the thermostat housing. Install the hoses to the heater tubes. Connect the upper radiator hose. 24. Connect the fuel lines, then temporarily connect the negative battery cable. Cycle the ignition to pressurize the fuel system and check for leaks. Turn the ignition key back and forth (from ON to OFF) at least 6 times, leaving the key ON for 5 seconds each time. If no leaks are found, disconnect the negative battery cable and continue the installation. 25. If removed, install the distributor, aligning the housing and rotor with the marks that were made during removal. Install the distributor cap. Position the spark plug wires in the harness brackets on the rocker arm cover attaching stud and connect the wires to the spark plugs. If the engine was moved with the distributor out, rotate the crankshaft until the No. 1 piston is at TDC of the compression stroke. Align the correct initial timing mark with the pointer, then position the distributor in the block with the rotor at the No. 1 firing position and install the hold-down clamp. For more information on distributor removal and installation, and for helpful hints on figuring out when the engine is at TDC, please refer to the distributor and timing procedures in General Information & Maintenance in this repair guide. 26. Install a new gasket and the upper intake manifold. Tighten the bolts to 12-18 ft. lbs. (16-24 Nm). Install the cover plate and connect the crankcase vent tube. 27. Connect the accelerator cable, TV cable and cruise control cable, as equipped, to the throttle body. 28. Engage the wiring connectors and vacuum lines as tagged during removal. 29. Connect the coolant hoses to the EGR spacer. 30. Install the air intake duct assembly and the crankcase vent hose. 31. Connect the negative battery cable, then fill and bleed the cooling system. 32. Run the engine to normal operating temperature and check for leaks. 33. Operate the engine at fast idle. When engine temperatures have stabilized, check the intake manifold bolt torque values. 34. If the lower intake was removed and/or the distributor was disturbed, check the ignition timing.
374RWHP/354TQ Dynotuned by Danny Swanson from SwansonPerformance |
Moderator
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!! |
Thats a good link. you could also pick up haynes or chilton manuel
thanks a lot guys i love this website...i think im in love with each and every one of you
Threads Similar to: Manifold Installation
| LED Installation | Devthedevastator | Visual | 1 | November 5th, 2007 07:15 PM |
| How much is installation? | NeoAnderson48 | V6 Mustangs | 14 | September 3rd, 2007 05:26 PM |
| No name single plane manifold VS Victor Jr manifold | hitorx | 5.0 Mustangs | 5 | May 11th, 2007 08:47 AM |
| FS: 4.10s with installation kit | Aliate X | For Sale | 62 | May 10th, 2007 02:49 AM |
| Swapping a 98 V6 intake manifold with for a 99 V6 manifold | 98mustang | V6 Mustangs | 5 | September 24th, 2005 10:27 AM |
