Discussing How Would I Know What Gearing Is In My Stang in the 5.0 Mustangs Forum. I Have An 87 Gt, I was Wonder If Anyone Would Roughly Know What Gearing ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
!987 Mustang Gt (Summer Car) - Ford Racing Headers, Flowmaster American Thunder Exhaust Without Cats, Flowmaster Hushpower 2 Mufflers, March Performace Ram Air Kit And Pullies, BBK Short Throw Shifter. 1997 Ford Taurus SHO (Winter Car) |
Hmmm...
SLOW
Get your car up on a lift...
Mark the drive shaft and the tire with chalk... Count how many times the driveshaft goes around for every one round of the tire... That is the easiest way IMHO... If the driveshaft turns 2 3/4 times for every one turn of the tire you have 2.73 or so... If the driveshaft turns 3 times then you prolly have 3.08's... Drivshaft turns 3 1/2 times for every turn of the tire then you prolly have 3.55's... Driveshaft turns 3 3/4 times then you have 3.73's... If the the driveshaft turns 4 times then you prolly have 4.10's... Hope this helps... |
+1 Thats definetly the easiest way. But from your RPM's it sounds like you might have 3.08's or 3.27's in your car. In my 93 with 2.73's, I am at about 1800 at 70 mph... or close to it; that may not be exact.
http://i25.photobucket.com/albums/c5...8bluegt6wk.jpg 93 GT - Full Exhaust, 3.90's, Front Tubular Suspension, etc. 88 GT "Big Blue" - Body work & primer! |
Hmmm...
SLOW
I forgot to put the 3.27 in there lol...
If your drive shaft turns 3 1/4 time then you prolly have 3.27's... |
how far off will my speedometer be when i put my 4:10s in? the gears are stock right now, i dont know what they are in a 90 LX 5.0 auto, but i wanted to know if i have to get a new speedo cable or not? Thanks
393 dropping in a foxbody near you, very very soonMilitary Crew E-3 Combat Engineer |
1984 GT
13.79@98.99
I couldn't find what size gear is inside your trany 6,7, or 8 ( which you need to know ) but here is good article on speedo gears and rear sizes
http://www.ffcobra.com/FAQ/speedo.html jjg
Eibach Sportsline, Mac, Moroso,Comp Cams,PRW roller rockers, and no money left over. |
I'm Thinking Of Putting 3.73 Gears In, How Much Will The Speedo Be Out And How Do I Adjust It Propertly
I have 3.73 gears in my car. I have to divide what the spedo says by 2 so 120mph im really only going 60. makes a cool video tho...I can get upto 140 in about 6 sec.
1984 GT
13.79@98.99
If you have an 87 GT with the orginal T5 in it, inside driving the speedo gear you have a 7 tooth gear. With 3.73 in it you would need a 21 tooth gear. Unless you had taller profile tires. The website in my first post ( above ) has a applet that calculates all those things. Just enter you tire size and speedo gear inside the trany and it will tell you what you need.
I have an 84 with a trany out of 92 which has an 8 tooth gear in it. So when I changed my rear dif I have to keep that in mind. jjg
#10 | |
1984 GT
13.79@98.99
Your 90 auto has an 8 tooth gear driving the speedo gear. If you put 4.10's in you would need a 23 tooth speedo gear. No new cable just a new speedo gear. jjg
cool thanks for that info!
Threads Similar to: How Would I Know What Gearing Is In My Stang
| Gearing for a 94 5.0 | mxman292 | 5.0 Mustangs | 2 | July 29th, 2007 04:51 PM |
| gearing | Mustang RacR94 | V6 Mustangs | 9 | June 29th, 2007 12:13 AM |
| gearing | EBuck | 99-04 | 10 | February 17th, 2007 07:50 AM |
| Help (V6 Gearing) | uniqueblackstang12005 | V6 Mustangs | 7 | October 23rd, 2006 02:03 PM |
| gearing | 88notch | 5.0 Mustangs | 3 | April 26th, 2006 07:46 PM |
