SeaFoam Questions
Just wondering if anyone put seafoam in their engine? if so do you have any tips on what i should and shouldnt do when putting it in? and what were your results.
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!! |
I havent heard of this product. Is it something for the cooling system?
http://seafoamsales.com/motorTuneUpConsumer.htm
you can put it in different areas but it takes most of the carbon build up and blows in out your exhaust and cleans certain parts of your engine depending on where you put it it. its suppost to help with hesitation, pinging, stalling. my father said back in the day chevy had something like this and they said it was like a tune up in a can. ![]() probally 8/10 people swear by this stuff and says it really help and also helps restore loss power
My Stallion is Bigger!
My old boss swears by it but my buddy put a can in his 240SX and it fouled one of the cylinder plugs. But I don't think my buddy did it right. Either way it goes in your vacuum hose and the motor coughs and chokes white smoke for about five minutes and then it runs a HELL of alot better. (Unless your my buddy of course)
yeah i heard that before that it can foul a plug. maybe cabon got on the plug
yeah im gonna try it. ill put it through the pcv valve and see how it works.
did he put the whole can in his car cause instructions say to only put 1/3 of the pint in it.
11.47@120.58
I heard seafoam is off the hizzy for shizzy. Never used it myself though, but seriously it's supposed to rock if you use it right.
1999 Ford Mustang V6
it has a few diff types of applications, but most will use it as in injector cleaner, like the lucas stuff or try to clean the carbon buildup out of the engine. they also sell it at northern for use with small engines like mowers and go-karts. the people who use it seem to swear by it.
93 GT
I put lucas in my motor once and slung 3 rods....
and it was still running. 1987 IROC-Z 350 TPI. One of 7000 made. Now Bossman has it.. kinda... or do I own it again????
Ok well my experience with seafoam is great. I just put it in. I originally wanted to put it through the pcv valve but I found it was easier to put it in the break booster line. I started the car and let it idle for a little until it got warmed up. I unplugged the break booster line and made sure it had good suction and poured roughly 5.5 oz of the seafoam in a cup and let the vaacum suck it through the vaccum tree and pretty much instantly the car began to smoke out the tail pipes. Plugged back in the break booster line and shut off the car for roughly 5 minutes. Started it up again and watched all of the smoke coming out the tail pipes again. I let it idle for a minute or so and took it out for a spin. The throttle response has greatly increased. No hesitation, I noticed a smoother, steady idle. A little power icrease, not much but noticible.
But just like the warning says on the can, when you put in the seafoam make sure you are in a well ventilated area cause you will be putting on one hell of a smoke show and it stinks. I highly recomend this product and give it a 10/10 and 2 thumbs way up. You can get it at your local advance auto parts store. Costs about 5.00 and well worth it in my opinion.
I think I NEED this stuff. I have a feeling my entire engine is now filthy.
Ford and GM both have a version of this stuff and it works good. By the directions with the engine hot, using a vacuum hose such as the pcv valve or just slowing pouring it through the carb(if old-school) put about half a can in and let the engine sit for about 20-30 mins. this allows the carbon to soak it up and soften it. start the engine and slowing injectthe rest of the can and then snap the throttle from about 1500-4000 rpm several times rapidly and then go look and see what come out the tailpipes. you'll be amazed if your engine was carboned up.
1999 GT Rag
never@ran
what if you dont want black ( non-rubber ) stripes down your driveway?
#14 | |
I don't knwo about all that hocas-pocas stuff. I'll stick to the old fasioned way of cleaning thing... taking them apart.
#16 | ||
1999 GT Rag
never@ran
Ok, I understand now. When I was still working at the dealership, we used a 3 part cleaning system by BG. This stuf was the shizzle too. One part was run through the fuel line, another part was run through the vacuum line and the other part was added to 10 gallons of fuel and run till nearly empty. (Hey Reds, Ive still got some of the old tokens in my tool box!
) The BG salesman came by and did some demonstratons for us and I was sold on it. Its not really "Hocus Pocus", It actually makes a lot of sense once you see the presentation.
OK I use this at a garage where I used to work and the boss said it is really just a mix of alcohol and water and he gets his bottles from NAPA. The shit works though!!! I used it on the ole 6 banger and she was HAPPY like ya read about! I think I am gonna start doing this with each oil change!
1985 Mustang GT
14.72 @ 93.84
put some in my truck this morning, right into the carb, and that shit worked awsesome
awesome man.
Threads Similar to: SeaFoam Questions
| Seafoam? | MustangMatt96GT | The Clubhouse | 21 | October 20th, 2007 05:30 PM |
| how do u seafoam? | ricerraper33 | V6 Mustangs | 11 | October 8th, 2007 09:19 PM |
| seafoam | mpboy | 99-04 | 16 | September 14th, 2007 02:25 PM |
| Seafoam | Juggalo_X | V6 Mustangs | 49 | May 25th, 2007 12:40 PM |
| Seafoam | MustangMatt96GT | 96-98 | 17 | May 18th, 2007 06:13 PM |
