Installing shocks/struts
Old March 24th, 2008, 10:38 PM   #1
Burn'nRubber's Avatar
1992 Mustang GT
Coming soon...
Burn'nRubber is on a distinguished road
I ordered a set of KYB GR2 shock/struts the other day, and am planning on installing them sometime this weekend. After looking around it all seems pretty easy, but i know looks can be deceiving. I was wondering if any of you have done this yourself? Any tips/pointers/instructions? Difficult? How long did it take ya?
Thanks
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work
Old March 24th, 2008, 10:42 PM   #2
ryans88gt's Avatar
I believe you need to do a front end alignment after you replace the struts. Other than that, shouldn't be too hard. The rears shouldn't take more than an hour, should be less if the hardware is not rusted together.
Old March 24th, 2008, 10:48 PM   #3
1992 Mustang GT
Coming soon...
Yeah Im planning on having an alignment done after the install.
Old March 24th, 2008, 10:56 PM   #4
ridebmxfbm's Avatar
1988 Mustang GT Vert
ridebmxfbm is on a distinguished road
The Shocks were really easy to get off, but the struts didn't come out easy I had to get an impact gun to get it to come off... It was stuck and make sure to get all brand new strut mount bushings etc...
1988 GT Vert- 306 AOD built Trans, K&N Cold Air Intake, Mac Catback, many more mods... MAC Long Tubes Coming soon, Dr. Gas Custom X Pipe, 347 Stroker Kit Coming Soon...
Old March 24th, 2008, 11:01 PM   #5
nolife's Avatar
91GT, 88GT, 02GT
I did mine about 10-15 years ago. Very straight forward and it is an easy job. The only part I remember having any problems with was taking off the upper strut nuts. The whole upper part of the strut kept spinning instead of just the nut. I think I ended up cutting the upper plastic sleeve off the stock strut in the wheel well and using a pipe wrench to hold the strut shaft while turning the nut. It completely trashed the shaft but your replacing them anyway.
Looking at the top of the strut from the engine compartment, you will see a slot in the shaft that looks like you could stick an extremely large flat screwdriver or a chisel or piece of metal stock etc in there to hold the shaft while using a boxed end wrench to turn the nut but attempting that only lead to bloody knuckles. It wouldn't hurt to get some WD40 or PB blaster on all of your bolts now.
Old March 24th, 2008, 11:10 PM   #6
1992 Mustang GT
Coming soon...
I take it the bushing is between the strut and the strut tower? You have a link/picture of these?
Edit: These what your talking about?
Prothane Front Strut Mount Bushings - For 83-04 Mustangs - StangSuspension.com
Old March 24th, 2008, 11:31 PM   #7
ridebmxfbm's Avatar
yes... those lol I kept the old ones and now they're all messed up and have to change them...
Old March 24th, 2008, 11:46 PM   #8
1992 Mustang GT
Coming soon...
yeah im not real sure how those 3 parts go together on the strut, but I guess ill find out this weekend. Im probably going to order mine threw autozone or O'reilly though, big spender here!
Oh almost forgot...how much does a front end alignment usually run?
Old March 25th, 2008, 12:14 PM   #9
ridebmxfbm's Avatar
It will depend on where to go to get it done, I know mine is $60 for each side so $120 all together... Are you getting springs too or no?
Old March 25th, 2008, 12:57 PM   #10
1992 Mustang GT
Coming soon...
Not at this time, due to not having the funds and not knowing if I want to lower the car or not. I know it would be best to replace the coils as well.
Threads Similar to: Installing shocks/struts
Shocks and Struts? chris1 4V / SVT 17 May 12th, 2009 10:16 PM
Installing New Shocks/Struts On A 95 SPF0percent General Tech 1 December 7th, 2007 06:24 AM
Shocks Struts, and Quad Shocks? 2000roush 99-04 2 December 4th, 2007 08:27 PM
KYB shocks and Struts ridebmxfbm 5.0 Mustangs 2 August 19th, 2007 02:34 PM
shocks and struts? MisterFast3 V6 Mustangs 2 July 31st, 2007 08:01 AM
