PCV valve
Old October 11th, 2006, 10:41 PM   #1
83 5.0's Avatar
83 5.0 is on a distinguished road
PCV valve
Installed an RPM performer and edelbrock carb on my 93 engine. Trying to figure out what to do to hook up a PCV valve with the stock 93 valve covers. Saw an inline type at the local parts store but wonder if it would hurt performance as I don't know what engine it's from.
Do I need it first of all? The older V6 engine used a breather on one cover and the PCV was inserted into a grommet on the other cover.
How does the engine breath for the PCV as there is no breather on the other cover and no grommet on the other? Do I need different valve covers?
Thanks for any suggestions as I know zero about the PCV.
Old November 13th, 2006, 08:33 PM   #2
88mstang is on a distinguished road
yes,you do need to have the PCV because it releases pressure it the motor so ypu do not blow your seals
Old November 13th, 2006, 10:02 PM   #3
stang fanatic's Avatar
stang fanatic is on a distinguished road
you need older valve covers if you cant find any with pcv provisions. install the grommetts, put a breather in one and the pcv in the other
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old November 13th, 2006, 10:32 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You need different valve covers.
Threads Similar to: PCV valve
4.6 4 valve in a fox mustangboy8909 5.0 Mustangs 26 October 19th, 2009 01:05 PM
EGR Valve sorrowfulkiller 96-98 13 September 12th, 2007 12:35 AM
pcv valve? El_Cangri V6 Mustangs 12 June 1st, 2007 11:07 PM
new egr valve mikethetigerrr V6 Mustangs 9 April 29th, 2007 03:12 PM
Where Is It? (PCV Valve) cobraetti General Tech 3 August 6th, 2006 10:16 PM
