Clutches
Old October 27th, 2005, 12:58 AM   #1
My5point0Mustang is on a distinguished road
Send a message via AIM to My5point0Mustang Send a message via MSN to My5point0Mustang Send a message via Yahoo to My5point0Mustang
Clutches
I was thinking that after I get my car running right, the 1st thing that I wanted to do was replace the clutch. I like a stiff, hard to push and hold down clutch, what I wanted to know was who uses what, and on a scale of 1 to 10, 10 being the hardest how hard is it to push in and hold.
Thanks again guys.
The ever most annoying,
Greg
Old October 27th, 2005, 01:01 AM   #2
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
If youre going to race it or put lots of miles on it, you might end up regreting a "stiff" clutch. You will get tired of trying to stage with it or you will be wore out after a good city commute. Just my $.02.
Old October 27th, 2005, 09:24 AM   #3
thanks, but it doesn't bother me, because i have changed one before and its not that bad. well then what is a good stiff everyday car clutch
Old October 27th, 2005, 09:27 AM   #4
mdvaldosta's Avatar
11.47@120.58
For most 10.5" clutches I like the King Cobra, its cheap and holds strong to 400hp
Old October 27th, 2005, 09:32 AM   #5
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
King Cobra clutch=
Old October 27th, 2005, 09:41 AM   #6
IcantDo55 is on a distinguished road
King Cobra is made by Valeo and a quality clutch, Valeo makes all Fords stock clutches. I had one on my last motor puting 500 to the wheels. I also have one in my daily driver. Works great.
Remember its not a race clutch, no slicks!
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old October 27th, 2005, 10:47 AM   #7
so on cobra r rims and tires king cobra clutch works????
Old October 27th, 2005, 11:01 AM   #8
yes, I agree. King Cobra clutch is probably best for what you want. It holds good and not to stiff to push down. Living in Tidewater, you don't want a stiff clutch on a daily driver. Now with that said, if a lot more power is being planned, take a look at Spec clutches. Also, stay away from the dual disc clutches, huh Mike?????
88 Mustang Coupe
www.rickscarcare.net
Old October 27th, 2005, 11:15 AM   #9
fallstar01 is on a distinguished road
A friend of mine has the King Cobra Clutch along with a MM quadrant on his 93 GT. Feels great. I recommend reusing the stock cable.
Old October 27th, 2005, 06:36 PM   #10
McCloud Clutches! Rant off.....
I have a Spec 4 here waiting for a install.
-Mike
Link to My Site
Stroked and Blown!
Old October 27th, 2005, 07:07 PM   #11
173speed is on a distinguished road
what if your runing drag radials will the king cobra hold ? why not the dual cluch? and what do u guys think of the ram cluch?
SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$%
Old October 27th, 2005, 09:21 PM   #12
depends on the power level of the engine, launch rpm, etc. personally, ever Ram clutch I have ever installed would shake your teeth out upon engagement unless you side-stepped them.
As for the dual disc clutch, they are a pain in the ass to get to release and engage properly and smoothly. You have to measure the clearance between the discs and the plate and flywheel w/ the clutch pedal pushed in and shim accordingly to get the clearances needed for smooth, noise-free operation, throw a Lakewood sfi bell into the mix and it's impossible to do as well as it's another pita getting the clutch pivot height correctly w/o killing the release bearing or hitting the pressure plate while the eng is running. For the icing on the cake, throw all this in a cobra with long-tubes which requires the rt side header to have to be removed along w/ the starter in order to remove the bell and trans and by now, you should be getting the picture. Mike's problem was slightly different in that all this stuff was never meant to be put in a fox-body.
88 Mustang Coupe
Old October 27th, 2005, 09:30 PM   #13
lol
Old October 27th, 2005, 10:09 PM   #14
thanks for the info one more question i hope i don`t sound dum
what is side-stepped ?
Threads Similar to: Clutches
Clutches? HELP? DRANEY302 94-95 9 October 22nd, 2007 03:20 PM
Clutches jonnotch 5.0 Mustangs 11 March 10th, 2007 10:39 PM
shifters and clutches. help! patwrecked 5.0 Mustangs 13 March 9th, 2007 10:56 PM
Spec Clutches 4point6GT 96-98 6 June 27th, 2006 07:49 PM
Clutches? Stan27 General Tech 16 May 5th, 2006 10:24 PM
