How does rocker arm add horsepower?
Old March 29th, 2008, 07:37 PM   #1
noyz25 is an unknown quantity at this point
How does it make horsepower by just changing them to like 1.6 aluminum? And whats better 1.7 or 1.6? I tried searching before posting cuz i was embarrassed to ask but no luck.
Old March 29th, 2008, 07:39 PM   #2
MM's Mad Scientist
acmillr's Avatar
Slow Fella
acmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to beholdacmillr is a splendid one to behold
Going up in ratio increases valve lift allowing your engine to breathe better. In some cases it could also cause piston to valve issue if you are already a little tight.
Old March 29th, 2008, 07:55 PM   #3
1987 ford mustang gt
well see when shes done
+1 to acmillir and if you dont ask then you will never know and we are here to help not embarrass you.
Old March 29th, 2008, 08:37 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The change to a roller fulcrum is a minimal horsepower gain but it will offer reduced friction as well as allow more travel for more lift, increased spring diameters and more spring pressure. A 1.7 ratio will increased valve lift over a 1.6 ratio which will provide some small horsepower gains.
Old March 29th, 2008, 08:43 PM   #5
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
As always (so far) he is very correct! Fulcrum, ost have no idea what that is LOL
Threads Similar to: How does rocker arm add horsepower?
Roller Rocker Arm Kit scxc15 V6 Mustangs 24 January 25th, 2008 08:09 AM
Stock Rocker? 88mysticgt 5.0 Mustangs 23 January 4th, 2008 10:43 PM
Roller Rocker help sniperrider 5.0 Mustangs 12 August 31st, 2007 10:00 PM
roller rocker ? marcd 5.0 Mustangs 15 June 25th, 2007 10:35 PM
Rocker arm questions Maxwell881 5.0 Mustangs 2 March 25th, 2007 07:24 AM
