#21 |
Those ford cams are lazy. They were great in the 80's before anyone knew what was really happening with ramp rates and lobes in regards to hyd rollers. Look at some of the junk from Comp, XE series or a TFS Stg 2. Measure PTV clearance and move forward, pretty simple stuff.
#22 |
2003 Ford Mustang GT Vert
the F303 will fit with changes needed. the X303 wont unless you adjust the valve to piston clearence.
that is all :
#23 |
1987 ford mustang gt
well see when shes done
#24 |
1990 LX hatch
#25 | |
#26 |
Yes, it is very possible. There are many ways to come up with 224 duration which many people don't realize.
#27 |
#28 |
1990 LX hatch
Ramp, and lobe seperation angles...yes I do understand how cams work. My point is just that a custom grind, just like titanium valves are better. But not a nessessity to 80+% of the members.
#29 | |
Valve timing events produce duration and lobe separation. You can have two cams with the same duration and lift and one will kill the other in horsepower and torque. That was the point I was making. Custom grinds have nothing to do with the point I was making. Is cam #1 the same as cam #2? The duration and lift are the same so the cams must be the same, right? Cam #1 IVO-26 IVC-62 EVO-74 EVC-22 Intake duration – 268 @ .050 Exhaust duration – 276 @ .050 Intake lobe lift - .454 Intake lobe lift - .422 Cam #2 IVO-36 IVC-52 EVO-68 EVC-28 Intake duration – 268 @ .050 Exhaust duration – 276 @ .050 Intake lobe lift - .454 Intake lobe lift - .422
#30 | |
1990 LX hatch
#31 |
Atomized
now you guys are just showling off
#32 |
hahahhahah
#33 |
No, they both have 268 at @.050 intake and 276 @.050 exhaust duration. Cam 1 lobe separation is 112 and the overlap is 48 degrees. Cam 2 lobe separation is 104 and the overlap is 64 degrees. The valve timing is what makes the difference in power, not the duration or lobe separation.
#34 | |
#35 | |
1990 LX hatch
I understand the performance oriented timing, and the fact that we havent touched the subject of ramp profile, but that was not my point. My origional point was that 2 exact cams, will make the same power. in the same motor....degreed the same.... dynoed in the same dyno....with the same temperature...with the same humidity...at the same elevation...
#36 | |
I was commenting on where you said "a new .512 224* lift cam will make more power than an out dated .512 224*lift cam". Yes, it might because it might be a different grind that might have the same duration and lift but in fact be a much different cam. That is the point I was trying to make. Then you commented about ramp and lobe separation angles are used to come up with duration figures which is wrong so I explained it. I wasn't intending on creating a pissing match, I was just explaining how it worked.
#37 | |
1990 LX hatch
#38 |
ok guys.. just answer his question straightfoward... if you want a better cam, get a custom grind.
if you want a big cam, go ahead and have the chug, but its not going to run well.
1993 Mustang GT, catless h-pipe, bbk shorties, 40 series flows, bbk rear suspension, edelbrock front suspension, AUTOLITES!!! =), k&n, underdrives, 3.73's
Threads Similar to: Biggest cam in a stock 5.0?
| biggest tire on a stock 17 | RedStangGT | 99-04 | 23 | August 19th, 2010 07:36 PM |
| Biggest tire | flamed 98 gt | 5.0 Mustangs | 7 | October 25th, 2007 12:09 PM |
| Biggest Wheelsize for a 88-93 GT | Nociznice | 5.0 Mustangs | 7 | March 21st, 2007 08:19 PM |
| What is the Biggest cam with 202 valves on stock pistons | Kevin b | 5.0 Mustangs | 7 | January 3rd, 2007 12:21 AM |
| my biggest turn on | sAJ1420 | Multimedia | 9 | September 18th, 2005 09:48 PM |
