Idle Too High
Old October 14th, 2006, 06:40 PM   #1
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
Idle Too High
88 mustang lx 5-speed. it idles at 1500rpm the i was told from many sources its the idle air control unit. i just bought one at pepboys and put it on it still idles at 1500rpm but when i unplug the electrical connecter attached to the unit it idles right at a grand. somebody help me.
thanks
nick
Old October 14th, 2006, 07:32 PM   #2
Screemin3o2 is on a distinguished road
Send a message via AIM to Screemin3o2
put a t/b or anything on it lately? Check your idle screw. The service data calls for my year to idle at 680RPM
95 Mustang GT
Slow Bolt On Car
www.steelcitystangs.com
Old October 14th, 2006, 08:55 PM   #3
nope everything is stock as far as i know but its weird when i unplug the connecter it goes down to 1000 also some of the vaccum lines are half assed could that do anything to the idle?
nick
85 svo. work in progress
Old October 14th, 2006, 09:01 PM   #4
TENGRAM is on a distinguished road
nick
if the vacuum lines are leaking, yes it'll cause your idle to be too high and often will cause a lopey idle, but i agree with Screemin3o2 that you probably just need to adjust your idle screw on the TB. idle with the IAC unplugged should be ~650-700
89 GT t5 3.73
www.my5oh.com/
Old October 14th, 2006, 09:31 PM   #5
thanks guys ill check it out 2morro
nick
Old October 14th, 2006, 09:48 PM   #6
did this all of the sudden start doing this?
95 Mustang GT
Slow Bolt On Car
Old October 14th, 2006, 10:18 PM   #7
ive only had the car for about two weeks but seller told me about the idle issue it before i bought it. when i got the car the idle went up and down unless the iac was disconnected but i noticed the coolant lines to the egr were bypassed with a copper tube(the gasket needed to be replaced so the former owner bypassed it instead of replacing the gasket) so i reconnected the two lines(and put a new gasket in). the idle was now steady, but at 1500rpm.
Old October 14th, 2006, 10:29 PM   #8
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
did you check tps voltage at idle? what is it?
Old October 14th, 2006, 11:48 PM   #9
no i didnt check that, what should it read
Old October 15th, 2006, 12:03 AM   #10
technically .49-1.20vdc. to be safe i would make sure its between .80-1.00vdc
internet myth will say .98vdc, but its BS, since the ecm "zeros" out the base (closed TB) voltage at start-up and change representing part-throttle and WOT is determined by an amount added to that base, rather than a pre-determined voltage.
i just woke up, so that may not be too clear, for more info check out This Article on EEC mythology.
specifically post #2 (mythology case #1)
89 GT t5 3.73
www.my5oh.com/
Old October 15th, 2006, 12:14 AM   #11
nothing ever has a simple solution ....
Old October 15th, 2006, 12:43 AM   #12
your not kidding...believe me i've done alot of experimenting with it, just make sure it is between .80 volts and 1.0 volts and it will be perfect. the voltage should be checked between the green and black wires, and can be checked with the key on (where you hear the fuel pump prime) and engine off.
89 GT t5 3.73
www.my5oh.com/
Old October 15th, 2006, 12:45 AM   #13
shadowgames81's Avatar
87 Coupe
shadowgames81 will become famous soon enough
I had the same problem problem on my 91 and I was told bout a spacer between the aic and throttle body and I put it on and fixed all my probs not sure if its gonna help but it was like 9 bux s it was a cheap fix no hurt to try
Old October 15th, 2006, 12:58 AM   #14
how thick of a spacer?
Old October 15th, 2006, 01:07 AM   #15
Bill is on a distinguished road
i need to get a new TPS tomorrow. im getting a code 63. saying TPS below .6 volts. piece broke that tells the computer how much gas your giving. and im getting a code 98 because of it. PCM running in Failure Effects Management Mode
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!!
Old October 15th, 2006, 01:18 AM   #16
BTDT, runs like ass in limp mode don't it? let us know if the new TPS doesn't fix it, we'll see what we can do
89 GT t5 3.73
www.my5oh.com/
Old October 15th, 2006, 01:54 AM   #17
87 Coupe
it was like a 1/4 in spacer an I actually bought it from the ford shop here in NN, VA an it stopped my idle probs and cost like 9 or 10 bux. not sure what they called it prolly somethin simple like iac spacer. my boy made one from alum himself and shaped an drilled holes and seemed 2 fix his idle probs 2 man
Old October 15th, 2006, 11:42 AM   #18
91GRNGT's Avatar
91GRNGT is on a distinguished road
Send a message via MSN to 91GRNGT Send a message via Yahoo to 91GRNGT
there is a spacer??? my idle is constant at 850 or maybe 900, is this too much?? I figured it wasn't past a g so why not lol
1991 Mustang GT 306, with KB .30 over pistons, steeda #18 cam!
05 Dodge Neon "Daily driver" Does dodge and ford match???
Old October 15th, 2006, 01:24 PM   #19
technically, idle should be 650-700rpm, but if your idle is steady i wouldn't mess with it.
89 GT t5 3.73
www.my5oh.com/
Old October 15th, 2006, 01:34 PM   #20
91GRNGT's Avatar
yes my idle is steady, Some times I guess it does do 700 it is a nice idle though.. wont mess with that..
Threads Similar to: Idle Too High
high idle RAMS#20 94-95 4 October 24th, 2007 02:23 PM
high idle then nothing msolaas1 2005 - 2010 4 October 10th, 2007 05:42 AM
High idle 8A_Honda 5.0 Mustangs 16 September 17th, 2007 07:53 PM
high idle buddie 94-95 1 June 30th, 2007 02:40 PM
Idle Too High DaveCarey V6 Mustangs 14 October 11th, 2006 11:17 PM
